Trouble free for quite a while now, but I guess when it rains it pours and got 10 codes all at one. The brake, abs, and traction control signs are lit up on the dash as well as the red car on a lift sign in the center information screen.
Looks like they are all canbus/k-can related. Read out from Carly -
Base: E90
Build-Year: 2011
Faults: 10
ECUs: 17
Filter: just found
Model: 3 (E90) Automatic engine recognition (MotorID=92, Parameter=31)
Battery: 14.2V
ADDITIONAL OBD: OFFEnhanced communication
Normal connection
Optimized: 14
B 2
Date: 2018-06-04 12:46:47
Carly Adapter
Version: 24
Device: >samsung< >noblelteuc< >SAMSUNG-SM-N920A<
Motor Control:
Engine / Motor
ECU OK, no Fault Code
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
Airbag:
Airbag
:Bus line fault - General. / K-CAN line fault - General.
Code: 00C944
Airbag B-pillar left/ B-Saeule links
ECU not present/no response from ECU
Airbag B-pillar right/ B-Saeule rechts
Transmission Control:
Transmission / Getriebe GS 19
Transmission / Getriebesteuerung
Gear switch / Gangschalter
Instrument cluster:
Instrument cluster / Kombiinstrument
:bus Off / CAN BUS OFF
Code: 00E107
Central info display / Zentrales Display
Light/Rain Control:
High-beam / Fernlichtassistent
Heating / AC:
Air conditioning / Klimaanlage
:CAN-BUS. physical bus error / CAN low, Physical bus error / CAN bus physical bus
errors / K-CAN Physical bus error
Code: 00E704
Immobilizer System:
CAS
:K CAN line fault / K CAN LOW SYS, Physical bus error D904
Code: 00D904
Park distance control:
Park Distance Control / PDC
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
Sunroof / Roof:
Sunroof / Schiebedach
Roof / Dach
:CAN bus CAN LOW error 0xDE84 / CAN line fault
Code: 00DE84
Audio/Navi/Communication:
Phone / Telefon
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Car Communication Computer CCC
:CAN low, Physical bus error / K-CAN line fault / CAN High / Low-Line Error.
Code: 00E184
MASK
Navigation
CD-Changer / Wechsler
Audio-System
Video
DAB
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Junction Box Passenger / Beifahrer
:Controller PT-CAN, Bus Off / K CAN Single Wire OPERATION / K-CAN
COMMUNICATION: OPERATION Wire
Code: 00C908
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
:Error CAN single wire / Error CAN low
Code: 00D104
Passive Go System
Car Communication
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Chassis:
Air suspension / Luftfederung
Body:
Automatisches Front Steering
Trailer / Anhaenger
Fussraummodul /FRM
:Bus line fault K-CAN / K CAN SHORT / Unfortunately, no error text available / CAN
low, Physical error
Code: 00E584
Dynamic manager / Dynamik-Manager
Other:
Advanced Telematic Module
:CAN bus: Short
Code: 00E147
Checked, and had some else check too, the battery and it's healthy.
Hoping someone could point me in the right direction...or if someone had the same error codes pop up.
Thanks in advance.
