No Heat
05-30-2018, 09:01 PM | #1 |
Robot
1685
Rep 2,191
No Heat
I searched and read numerous posts about the issue of no heat, but couldn't find any definitive answers.
I have no heat in my car. Not that I need it, but there are a few days in January and February where it would be nice to warm up a bit. I've read about clogged heater cores or improperly functioning heater control valves but didn't see any real solutions. My engine is up to operating temperature (205+), the selector between the vents is on the red setting, temperature is turned up all the way, AC is off, and the blower moves a nice volume of air, yet it's the same temperature as the outside air. The coolant was topped off and not low, no leaks in the system (not before tonight when I replace the oil filter housing gasket and the coupler from the thermostat hose to the cylinder head split). My radiator and thermostat were replaced in November so it's not likely the thermostat is bad. My car gets to operating temperature somewhat quickly and maintains normal temperatures (viewed in INPA). How do I start diagnosing this? |
05-31-2018, 12:24 AM | #2 |
456
Rep 2,749
did you ever replaced you engine pump ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
05-31-2018, 07:08 AM | #4 | |
Art Collector
2425
Rep 3,448
If you’re feeling brave and patient, here’s another members excellent DIY: https://www.e90post.com/forums/attac...6&d=1331031264 |
05-31-2018, 09:44 AM | #5 |
456
Rep 2,749
it is possible to wash out heater core without removing heater
simply disconnect heater pipes from engine compartment, connect external pump with reservoir with prepared mix and this can help my friend on e83 with N52 did so and it helped
05-31-2018, 09:46 AM | #6 | |
Art Collector
2425
Rep 3,448
Silly question, but what causes this? Corrosion in system? Impurities, or buildup of some kind? |
05-31-2018, 11:44 AM | #7 |
102
Rep 343
05-31-2018, 12:43 PM | #8 | ||
Robot
1685
Rep 2,191
Yeah.. not looking forward to that. I'll try the flush first. Quote:
I'll be losing a bit of coolant when I replace the coupler from the head to the thermostat, so I will first try flushing the heater core. At the same time, I think I'll flush the entire system with distilled water and then replace with the proper coolant. |
05-31-2018, 02:03 PM | #9 |
456
Rep 2,749
if you perform such flushing as i described before you'll see what it can be, because i truly do not understand how aluminium core can corrode when using bmw coolant
05-31-2018, 02:21 PM | #10 | |
Art Collector
2425
Rep 3,448
Sounds like PO used the wrong coolant. Good call on the flush. Hope it helps. Option 2 would be to find some heated seats (or just seat: fuck the passenger) and swap them in. I'm sure it'll be impossible to find them since you're in Cali, but I once had blower motor issues when temps were hovering around 0 degress F, and the heated seat made a world of difference. I'm sure with the temps where you are, this might be enough to stay comfortable. Ghetto, sure, but it would help and take no time compared to doing the core. |
06-01-2018, 09:57 AM | #11 | |
266
Rep 952
You could put perfect BMW coolant in the system, but if you don't change it in the next 10 years, you'll start having corrosion issues. Change your coolant every 5 years or so. In addition to corrosion, oil contamination is fairly common on the e90 platform due to the leaking OFHG. As a note, I don't recommend a flush as this can loosen build-up in the block and send it into the heater core, where it will plug up the heater core.
bone stock
06-02-2018, 06:12 AM | #12 |
356
Rep 928
Drives: 2007 328i Coupe, ZSP, Premium
I have the same issue in my car. I had the dealer do the flush (which is apparently the recommended fix, and it didn't really work). Probably the only remaining option is to replace the heater core, which is too expensive. So I rely on my heated seats. While the auto heat function does not work, after the car engine heats up, if you mess around with the controls a little bit (crank up the heat manually and aim the air to your face), you can sometimes get some warm air to come out of the vents. Not much, and it typically does not work when the temperatures are really low (in the teens). I also bought a small portable car space heater. It's not great but can keep your hands warm at least. If it's really cold outside, I just keep my coat on while driving.
I am curious to see if this heater recall will improve anything. |
06-13-2018, 11:27 AM | #13 |
Robot
1685
Rep 2,191
UPDATE
While replacing the hose from the thermostat to the head, I did two drain and fills using just distilled water (to get all the old green coolant out so I can fill the system with the correct BMW coolant). I now have some heat! It isn't as hot as it should be, but there is definitely heat.
Perhaps there is hope and a proper heater core flush can resolve it. |
