05-30-2018, 05:10 AM | #1 |
Rep 20
Coding 2TB (Sport Automatic Transmission) on G30
Hi.
I've tried to code 2TB on my g30 540ix which already has Sport+. I am only in for a faster transmission operation in general. What I did was edit the FA with E-sys, changed 205 option to 2TB. Then Load & Activated Modified FA. VO Coded BCD2_Body, EGS, DSC3, & DKOMBI2 In BCD2_Body FDL Edited "PADDLES_VERBAUT" to nicht_aktiv. Instructions for F10 also included VO-coding of ICM module which is not present in my G30. Could someone please confirm this is a sufficient list of VO and FDL changes, or there are more ECU's to code? Thank you very much in advance. After this is clarified, I will write a summary message in this thread so anyone willing to code 2TB will have a short and solid reference for G30.
Max Pavlov
06-17-2018, 10:02 PM | #3 |
480
Rep 1,360
Drives: 2015 MW - F80
What is you’re expected EMS resukt, and how will you know if you succeeded? Are you just trying to get higher revs before the automatic shifts?
03-05-2021, 04:47 PM | #5 | |
Rep 19
EGS Sportschalter: aktiv [01] And maybe (not sure) DSC: C_Variante_Testereinsatzkennung_c: 0F |
Tags |
2tb, coding, transmission |
