DIY Vacuum Canister Filter Fix for broken nipple
05-25-2018, 02:38 PM | #1 |
34
Rep 295
It is true that some people run without these and don't seem to have any obvious issues, however, I personally believe that will result in your vacuum pump duty cycle going up which could cause it to die sooner. Whatever the case, I prefer to keep mine.
One of the nipples on mine broke and I looked for brass fittings to replace it with, but couldn't find any locally so I decided to glue it. This is what I did to ensure a longer lasting solution: I matched a drill to the base of the broken nipple diameter and drilled into the area it broken off from. You can start with a slightly smaller drill size and then use a larger one if it's not bit enough. Don't drill too deep, it just needs to be enough to hold onto the end of the nipple, and make sure it fits snug. After you have the right size, take 100 grit sand paper and lightly rough up the end of the nipple that will fit into the canister. Then clean the contact areas with rubbing alcohol and apply the glue. Superglue will probably work fine, but I used 2-part, 5 minute epoxy to ensure it won't break again. Only apply glue to the outside of the nipple portion so that it has no way of plugging the airway. Then push it into place and let the glue cure. I added a little glue to the outside for good measure. |
05-25-2018, 06:23 PM | #3 |
319
Rep 1,023
Both are valid fixes. I just bought new ones.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
05-25-2018, 10:07 PM | #4 |
34
Rep 295
New canisters are a good way to go too since they are cheap, but I didn't feel like waiting for a part or driving to the dealership. It's good to know home depot has them, I went to AZ, then a specialty racing shop and when they said I needed to order online, so I did that, but didn't want to wait. It seems to be holding fine, so I'll run it until another one breaks off.
05-25-2018, 10:11 PM | #5 |
could-be bmw tech
17
Rep 71
Drives: %E2%80%9809 335i
Great DIY! I used JB weld to fix one of mine awhile back. Broke it clean off when the stock vacuum line wouldn't come off.
