Pure Highways 300di DAB unit
05-24-2018, 10:20 AM | #1 |
96
Rep 398
Drives: Merc, VW, Porsche, Suzuki
Seeing as my imminent new car already has DAB, I'm selling my old unit. It's the Pure Highways 300di unit, and I chose it because it has an aux-out, i.e. the audio plugs into your aux-in jack in your armrest cubby hole. You then just select Aux on your head unit, and whatever channel you want on the DAB unit.
I played around with various mounting positions of the unit, and ended up with it looking like this: So what you get is: The Pure Highways DAB module (hidden behind the heater controls on my car) The control panel which is mounted fairly robustly to the Brodit bracket you see in the picture All leads to wire it up & plug it in to the Aux-in jack What you don't get is: Any type of interface loom (I piggy-backed the Parrot loom in my car) The DAB antenna (destroyed when peeling it off the windscreen) This is my antenna on the far left of the windscreen: I can help install this, but you would need to buy whatever antenna you choose. Also you would need to come to Harpenden (near St Albans). £40 as is, £60 fitted using the antenna you provide. DM me if you're interested!
Audi A4 Quattro 2.0TDI 177 2012/12
VW Golf GTE Advance 2017/67 Porsche Boxster 986 2.7 2000/X Suzuki GSXR 750 2004/04 |
