05-24-2018, 09:42 AM | #1 |
296
Rep 610
Summer is here.....ventilate function
How long before using the car, sitting in the sun, do we activate the ventilate function from our phone app, to benefit the most from it?
2018 X3 30i SapphireBlack/ZMP/ZPX/ZDB
05-24-2018, 10:16 AM | #2 |
171
Rep 304
It doesn’t make a difference for me ,,, just blows warm air around a warm cabin
X3 M40i... Fully loaded
thelightning19.50 Oldgixxer1914.00 |
05-24-2018, 10:23 AM | #3 |
296
Rep 610
Hmmmm, maybe press and hold the button (on fob) that opens everything (windows and sunroof hatch) when just beginning the walk to the car (if safe).
deladude266.00 |
05-24-2018, 10:28 AM | #4 | |
171
Rep 304
I hope the ventilate option may be more useful in the winter?
05-24-2018, 10:30 AM | #5 |
709
Rep 1,066
The system will only run for upto 30 minutes in the comfort ventilation. You can program the system to cut on at a certain time to start cooling the vehicle but again it will only do so for 30 minutes. It does help to move air through the car but it isn’t remarkable. I did have an i3 and you could actually turn on the ac or heat remotely which was great.
05-24-2018, 11:45 AM | #6 | |
867
Rep 6,248
I ventilate 20-30 minutes before I plan to get in the car. Works well. The newest app updates doesn't fail as often as it used to. |
05-24-2018, 12:20 PM | #7 |
430
Rep 1,115
Anyone with the display key know how to set a time or even get the system to go? Mine was greyed out and didn't function when I tried to use it last.
05-24-2018, 01:13 PM | #8 |
1455
Rep 1,487
Drives: 2108 X3 xDrive30i
The ventilate function on my BMW's is wimpy. It doesn't cool your car down at all. It gently blows ambient temperature air around the cabin for however long you set it. I think its was designed so that when you get in the car that's been sitting outside the air inside the car isn't stale.
05-24-2018, 08:01 PM | #9 | |
296
Rep 610
It must be “ventilating”as it’s function title suggests.
05-26-2018, 07:21 AM | #10 |
232
Rep 380
I don't have any such button on my fob that i'm aware of, do M40i fobs have this feature?
'24 Macan S
Prior: '21 X3 M40i Dark Graphite/Black '18 X3 M40i Carbon Black/Cognac '15 X5 xDrive 30i M Sport Space Gray/Mocha |
05-26-2018, 08:22 AM | #11 |
82
Rep 152
For all other BMWs I've had just holding the unlock button on the FOB would roll down all the windows and open the sunroof. I assume it's the same for this car (haven't tried it yet).
deladude266.00 |
05-26-2018, 08:31 AM | #12 |
Rep 25
Guys, this cant work really. I have had a broken AC twice in my cars. If the air is simply blown in with the fans, it is first moving through very hot parts at the front of the car. This makes it more of a heater than a ventilation.
Ventilation on a standing car works - but only with the new electric AC compressors, such as in the 330e! Or, wherever it is legal (not in the EU unfortunately), with the remote engine start.
waiting for my G01
05-26-2018, 03:44 PM | #13 |
Head Idiot
251
Rep 551
07-12-2023, 03:41 PM | #14 |
Rep 5
5 year old post about to reignited because I just picked up a 2014 x3 M, and only just learned about this function. Couldn’t figure it out until I realized it wasn’t a timer… although according to you guys, apparently it is. So, I set mine for 1pm, and waited. 1:01pm came and it activated on its own. I didn’t stick around to ensure that it turned off after 30 minutes.. but I’m assuming that’s what it’ll do?
Usachampion189.50 |
07-12-2023, 04:35 PM | #15 | |
1284
Rep 965
07-12-2023, 04:36 PM | #16 | |
4442
Rep 7,485
I have the 2nd programmable button set to take me directly to this CLIMATE setting so that anytime I need to use this feature...it is one button press away. I also use it when it is extremely hot/humid and I'm parking in an enclosed or dark parking location with low ventilation. A dark low ventilation location is prime for the growth of bacteria & mold...which can end up becoming AC funk if you find yourself parking in a dark low ventilated location a lot. You can see a screen shot below of the CLIMATE setting screen where you can program up to TWO timed ventilation events...or you can select the activate now (again, this can only be done when the engine has been turned off but the car is still powered...instructions are in your owners manual if you can't figure it out...plus there's an owners manual built into iDrive which you can read right there in the car while trying to use the feature).
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
07-13-2023, 06:00 AM | #17 |
405
Rep 840
I'm not sure about hybrid X3's, but the electric iX3 runs the full climate control using whatever temperature it was set to when you turned it off. Only ten mins leaves a lovely cold car. Plus the bonus is the seats cool down when nobody is in the car, so you sit down on nice cool leather!
07-13-2023, 06:59 AM | #18 | |
815
Rep 2,869
The feature is literally called "ventilation", not "cooling" ... its just to get fresher air into the cabin, whatever the air temp is outside is the air it's going to freshen the cabin with. it may help marginally but is not AC obviously.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 Last edited by AllBlackBimmer; 07-13-2023 at 10:03 AM.. |
07-13-2023, 07:09 AM | #19 | |
10161
Rep 8,626
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
07-13-2023, 08:57 AM | #20 |
1284
Rep 965
Sorry - yes. I should have added that to my entry above… there is ZERO A/C done with this option/item… it is simply pushing (as mentioned above - ambient) air through the vents. The catch is… if you have some windows cracked for “venting” and you use this function, in theory, it will help “push” some really HOT air from inside the car to the outside… at least a little. If your windows are all closed, I can’t see it helping even the least little bit. Just my 2 cents…
07-13-2023, 09:17 AM | #21 | |
2699
Rep 4,292
As said, don't expect aircon cool, but it feels less hot compared to not using it. |
TXGrey1284.00 |
07-13-2023, 03:10 PM | #22 | |
4442
Rep 7,485
pic below shows one of the "flow through" vents (in the trunk of my old e38's battery compartment) that allows air to escape from the interior to reduce cabin pressure as doors open/close and when the HVAC blower is running: These vents are there to prevent air pressure build up inside the cabin. If these vents weren't there...your doors would be very hard to close because the air pressure built up in the cabin would bounce the doors back open. Same occurs when the HVAC blower is running...if there weren't any vents to the exterior...the air pressure in the cabin would build up. So when your car is sitting in the hot sun all day...if it is 80° F...after a few hours it could easily rise to approx 120° F: How hot do cars get in the summer? Using the Ventilation feature (for non-hybrids)...turning on the HVAC blower may not COOL the interior down as if the AC was running...but bringing in ambient temp air can still help reduce the temp inside the interior if it has been sitting in the sun all day.
TXGrey1284.00 |
