BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
Mporium BMW
      06-15-2008, 06:44 AM   #1
IWC Doppel
Drives: 08 M3
White Euro H&R springs with spacers and 18's
Guys a few piccies
      06-15-2008, 04:05 PM   #2
nlpamg
MBWorld Spy
316
Drives: M4 CSL, F8 Tributo, GR Supra
nice! what size spacers did you use?
      06-15-2008, 04:39 PM   #3
Big Windy
Big Windy's Avatar
152
Drives: None
looks ill. i'd be curious to hear your opinion on how this has affected handling and ride comfort. looks great though.
      06-16-2008, 05:54 PM   #4
IWC Doppel
Drives: 08 M3
10mm spacers all round
I might try 13mm on the rear to fill out a little more.
Regarding handling & ride comfort
Rise is marginally stiffer, feels a little tighter and planted. Little or no reduction in comfort.
I had it set up by a race team and they strung the car properly, factory was out especially at the rear. corner weights a little out (not adjustable)
After fitting springs corner weights much better, they reduced the toe in at the rear from factory and put 2mm toe out on the front. Cambers adjusted where possible (reduced ride height adds a little negative camber)
Turn in much better, steering feels weightier and more acccurate
Virtually eliminates float at speed
Body roll feels much reduced (I investigated aftermarket roll bars, it now feels much better and I am not looking any more !)
EDC seems better between settings, Normal is well balanced and my every day setting
Full stiff much better, no longer fidgety and bouncy if driven on a less than perfect road. When I am pushing on I choose full stiff and enjoy the hell out of it. Before I only got on with full stiff on the smoothest of surfaces as it simply felt unsettled
Adjustable susp now works, when driving hard the slight compromise on road surface transmission and stiffness is the right trade for a little more forgiving and surface absorbing ride. Both feel taughter and sportier
Overall I would say it's significantly better than stock and it looks much better too
I might try and raise the front 5-10mm as the weight balance does feel a touch more to the front (Spring drop 12mm F and 15mm R)
      06-19-2008, 10:51 PM   #5
Miami335i
Drives: 2008 E92 335i coupe
Looks really nice...
      06-20-2008, 01:06 PM   #6
BMW F22
BMW F22's Avatar
3566
Drives: ///M235i
Wow that looks great! Very flushed!
      07-07-2008, 06:07 PM   #7
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Very Nice
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      07-08-2008, 01:02 AM   #8
Davinhci
Davinhci's Avatar
55
Drives: 08 M3 E92 & 08 E70 X5 4.8
2008 M3  [0.00]
looks awesome!
08 E92 AW M3 | HRE P40 19" | APE Air Filter | BMW Performance Grills | White Side Gills | CF Mirror Covers | BMW Performance Pedals | F1 Pinnacle Tint | V1 Hardwire | Dinan Performance Software | Gintani Exhaust | H&R Sports Springs | RPI Scoops | BMW CF Spoiler | Challenge Diffuser | Lux H8 V3 | LCI Tail Lights |
      07-08-2008, 05:24 AM   #9
KKSigs
M4 CSL FBG
KKSigs's Avatar
1268
Drives: M4 CSL FBG
beautiful setup
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World
08' E92 M3 Jerez Black
      07-21-2008, 11:29 AM   #10
IWC Doppel
Drives: 08 M3
I tried 12mm rear spacers, fitted fine and looked great. I didn't expect to feel any difference. BUT I thought I must be mad it felt a little less together and seemed more unsettled at the rear a little less fluid and balanced.
Okay I thought, must be me, I checked with a few suspension Guru's to confirm my paranoia and they did just that 2mm per side increase in track, no way would I feel that on a road car, they didn't believe I would feel this on a race car.....
No problem I carried on and still felt the same about the car but grew to get used to it, didn't feel as bad after a few miles. It sort of changed from a very well balanced fantastic confidence inspiring car to 90-95% of that but with a little inbalance on turn in reminded me of a car with imperfect corner weights.
After a week I swapped back to 10mm to confirm my paranoia and guess what.........
The car feels better balanced, more fluid and more together on transition and weight transfer
Boy these cars are like Hi-Fi can't make sense of why a set of cables sounds different....
Any ideas !!!
      08-31-2008, 07:15 PM   #11
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
89
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
This would solve my one concern with this mod. Raising the front end will restore the lower control arm geometry. What do you use to raise the front end? Rubber spring pads? Some other firmer material?
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now.
Why, yes. I am an abrasive bastard.
      09-01-2008, 12:31 AM   #12
IWC Doppel
Drives: 08 M3
When looking at this Im can see no easy way.
One thing I was looking at was top mounts as the e39M5 I had ran DINAN top mounts and these raised the front (before adjustment from PSS9's at the time) by 5mm or so.
However the car is handling very well as it is at the moment and I may raise and not like the results !
      09-01-2008, 12:51 AM   #13
IWC Doppel
Drives: 08 M3
Looks good too
      09-02-2008, 05:40 PM   #14
ModBargains.com
475
Drives: JB E92 335i
Very nice. So clean and fresh
      09-06-2008, 12:11 AM   #15
Krueger///M3
Krueger///M3's Avatar
122
Drives: 2003 HPF 2.5, 2008 M3 (Sold)
2002 BMW ///M3  [0.00]
2008 BMW ///M3  [0.00]
Looks awesome, just like mine.
      09-10-2008, 12:00 PM   #16
eclipsisNA
350
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [7.76]
Where did you get your spacers and springs?
      09-10-2008, 12:47 PM   #17
!Xoible
832
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
theyre available anywhere... u in LA or OC? i can point u to a few shops if u want (pm me)
@ OP: how's the ride quality after a couple of months? same? different?
      09-10-2008, 02:26 PM   #18
IWC Doppel
Drives: 08 M3
Still driving great, no difference after 7,000 miles
      09-10-2008, 02:56 PM   #19
M2381
M2381's Avatar
32
Drives: E92 M3, GTI
I would do this but I'm already bottoming out in a lot of places...most of the time its when I'm being careful too(coming out at an angle, basically idling to pull out)
      09-11-2008, 01:48 AM   #20
IWC Doppel
Drives: 08 M3
Bottoming out with suspension dampers hitting bump stops or clearance with spoiler etc ?
      09-17-2008, 03:03 PM   #21
booforty
booforty's Avatar
337
Drives: E92 M3
2008 E92 M3  [0.00]
Very nice mate
      10-14-2008, 08:34 PM   #22
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
I think he means clearence. Aren't these springs stiffer than stock anyway? Also, have you tracked the car with the new springs?
m3post
