05-11-2018, 07:23 AM | #1 |
97
Rep 399
Drives: 2023 BMW i4 eDrive40
Engine Coolant Level Check
According to the Owner's Manual, you have to check the coolant in both of the reservoirs in the X3 xDrive30i B46 engine compartment. I looked in both and I only see a level mark in the smaller reservoir.
Do I use the embossed arrow on the outside of the larger reservoir???? Thanks wallyf Last edited by WallyF; 05-11-2018 at 12:18 PM.. Reason: Updated info from Owner's manual. |
05-11-2018, 05:24 PM | #2 |
97
Rep 399
There are Two Embossed Arrows
There are two embossed arrows (one pointing down and one pointing up) on the side of the larger reservoir. The arrows are above and below the reservoir seam.
To bad that the owners manual only tells you how to check the smaller reservoir. Wallyf |
05-12-2018, 11:51 PM | #3 | |
1455
Rep 1,487
Drives: 2108 X3 xDrive30i
The smaller of the two is easier to understand. I agree. Onthe large white tank at appx. the 7 o’clock position is a downward pointing arrow above the seam and an upward arrow below the seam. The space between the two arrows is the target zone. You don’t want to go above the point of the downward arrow tip and you don’t want to go below the the point of the upward pointing arrow. Target is the zone between the two arrows. Easier way to understand this is always aim for arrow point of the upward pointing arrow. And if you overfill a little bit try not go above the point of the downward facing arrow. |
02-23-2021, 07:34 AM | #4 |
2095
Rep 1,862
I do not see any embossed arrows on my tank. Do you fill it to the seam or am I missing something?
02-23-2021, 07:41 PM | #5 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3512
Rep 4,211
02-23-2021, 09:17 PM | #6 |
2095
Rep 1,862
05-31-2021, 01:33 PM | #7 |
24
Rep 92
Drives: BMW X3 M40i 330cic
What about type? I just purchased used with 9k miles and it has green coolant. Reason I know is I smelled coolant and checked the level which was all the way to the top of the small reservoir. So I used a turkey baster to get it right.
None of our previous 3 BMW's used the green coolant. I realize color doesn't tell everything with coolant, but green in a BMW? I also noticed whoever did the last oil change made a mess under the engine cover. So it has me worried.
2020 X3 M40i Blue
2005 Supercharged 330ci Silver/Black vert. |
05-31-2021, 06:12 PM | #8 | |
3512
Rep 4,211
