2011 E90 - Update bluetooth firmware
05-08-2018, 05:23 PM | #1 |
23
Rep 49
Is there any way to update bluetooth firmware without option SA 6FL, SA 6NH, SA 6NK, SA 6NL, SA 6NS, SA 6AE, SA, 6NR or the "Software Update" in iDrive? I am missing song information over bluetooth.
Don't know if this i relevant but I have option: S609A Navigation system Professional S612A BMW Assist S614A Internet, preparations S615A Expanded BMW Online Information S616A BMW Online S620A Voice control S633A Preparation, mobile phone, Business S676A HiFi speaker system S698A Area-Code 2 for DVD S6AAA BMW TeleServices S6ABA Control for Teleservices S6VCA Control for Combox NB: I have INPA, NCS Expert, ect. UPDATE: Retrofit and coding done. It all worked out!!! I Used this kit from eBay. https://www.ebay.com/sch/i.html?_fro...23608&_sacat=0 Coding guide: Adding Option 6FL Step One – Adding $6FL Open INPA and verify that it is connected properly. Close INPA when verified. Open NCSEXPERT and load profile Expertenmosus (Werkseinstellung). Press VIN/ZCS/FA (F1) Press ZCS/FA f. ECU (F3) Choose the E89 chassis Choose CAS or NFRM Press Enter FA (F2) Choose E89 Enter VIN: WBAxxxxxxxxxxxx OK Add $6FL OK Press Back (F6) Press Process ECU (F4) Choose CAS Press Change Job (F2) Choose FA_WRITE OK Press Execute job (F3) Press Change ECU (F1) –> Choose NFRM Press Execute job (F3) Step Two – Code changes to CIC Open INPA and verify that it is connected properly. Close INPA when verified. Open NCSEXPERT and load profile Expertenmosus (Werkseinstellung). Press VIN/ZCS/FA (F1) Press ZCS/FA f. ECU (F3) Choose the E89 chassis Choose CAS or NFRM Press Back (F6) Press Process ECU (F4) Choose CIC Press Change Job (F2) Choose SG_CODIEREN Press Execute job (F3) Press Process ECU (F4) Choose MEDIA Press Execute job (F3) Done Connected the eBay cable kit (Used black COMBOX plug) and Downloaded Bluetooth update from BMW update site, and updated. Now song information it displayed perfect. Last edited by MrNice2028; 08-30-2018 at 02:23 PM.. |
05-09-2018, 07:39 AM | #2 |
399
Rep 1,579
Since you have a combox you should be able to update. The USB in your arm rest connects to the combox in the trunk. If you put the new files on a USB stick and insert it into the slot, the idrive menu will allow you to update the combox bluetooth software.
Enter your vin here to check https://www.bmw.com/en/footer/software-updates.html |
05-09-2018, 10:45 AM | #3 |
Going topless
32
Rep 84
Drives: E93 335i, MX-5, RCZ R
I suspect that the issue is that the OP doesn't have a USB socket in his centre armrest!
(I'm in the exact same position and have just bought the USB socket and cable which will allow me to retrofit SA 6FL to my car, and hopefully also allow me to update my Bluetooth firmware). |
05-10-2018, 09:07 AM | #4 | |
399
Rep 1,579
05-10-2018, 12:13 PM | #5 | |
103
Rep 1,520
05-13-2018, 12:22 PM | #6 | |
23
Rep 49
That is exactly what I am missing:-) Will you write back when you are done with the project and sent me some guidelines how to retrofit and code the SA 6FL option? NB: Thanks for all the replys. |
05-17-2018, 06:32 AM | #7 |
399
Rep 1,579
When I did my 6FL retrofit this is the cable I used. https://www.ebay.com/itm/For-BMW-CIC...kAAOSwc2FaJKyR
It connects the combox to the OEM usb plug in the arm rest. In my car, the aux wiring ran to the back of the radio. I had to run new aux wiring to the trunk. Your car may already have that but check to be sure. |
