05-08-2018, 04:41 PM | #1 |
Rep 14
F31 Tailgate problem
I’m new here and not sure which section this goes in, can a mod move it to the right section if it doesn’t go here.
Neither the boot or the window will open on my tailgate, it doesn’t even make a noise when I press either button on the back or the one in the car. If I climb through the backseats and pull the manual release cable then the boot will open, and the softclose works when pressing either button and I can here the motor pulling it at the final bit and it locks but won’t open again. There is a constant error on the dash that the boot is open when it is closed. I have read the error codes with Carly and it is showing 804846 ZV-Driving rear window (MERHS): open circuit or short circuit to battery voltage. I’ve looked for the error on google and can’t find any results. My car is a F31 2013 (Ex-police) Thanks in advance. |
05-08-2018, 10:18 PM | #2 |
1455
Rep 1,487
Drives: 2108 X3 xDrive30i
Sounds like your valet switch is set to lock. In your glove box throw the switch to the unlocked position. Let me know if that works and Welcome!
05-09-2018, 12:17 AM | #4 |
Rep 14
I had a look on here and it looks like my car doesn’t have a valet switch. It has a silver blanking plate like the one on this thread
http://f30.bimmerpost.com/forums/sho...d.php?t=788584 |
05-09-2018, 12:19 AM | #5 |
1455
Rep 1,487
I can find that code anywhere. Did you scan through the OBD port? Do you have a valet key? If so try locking and unlocking the car. The only override I know is the valet switch to lock out the rear hatch.
05-09-2018, 12:26 AM | #6 |
Rep 14
Ye, I used the Carly app to scan and clear the dtc but as soon as I start the car it says boot open on the dash and then that dtc comes back? I tried locking and unlocking with the key but that did nothing.
05-09-2018, 12:29 AM | #7 | |
1455
Rep 1,487
05-09-2018, 12:31 AM | #8 | ||
1455
Rep 1,487
05-09-2018, 12:34 AM | #9 | |
1455
Rep 1,487
https://f30.bimmerpost.com/forums/sh....php?t=1436741 |
05-09-2018, 12:37 AM | #11 |
Rep 14
05-09-2018, 12:47 AM | #12 |
1455
Rep 1,487
Alright. If you have verified all the fuses are in tact and are properly seated the last thing I would do is open the hatch from the inside and when opened 1. press the close button for a slow count of 10. If it closes it should the open. 2. If not get a good fast drying solvent like brake cleaner and clean the latch in the in the tailgate. Other than that since it is a special police version it may have to go to the service center. I'll be reading this site for another 15 mins
05-09-2018, 12:52 AM | #13 |
Rep 14
Once it opens it soft closes fine. I just found this thread which seems like it’s the same problem as mine.
http://f30.bimmerpost.com/forums/sho...1328653&page=2 Seems like that dtc code is referring to the same area aswell. I’ll have to try and find a guide on how to get to the latch on the window. Thanks for your help. |
05-09-2018, 12:54 AM | #14 |
1455
Rep 1,487
Ok one other thing with the actual key. Insert the key into the drivers door lock. Lock the door then unlock it. Hold the key in the unlock position for a slow count of 10. Does this unlock your trunk.
05-09-2018, 12:55 AM | #15 | |
1455
Rep 1,487
05-09-2018, 12:55 AM | #17 |
1455
Rep 1,487
05-09-2018, 01:08 AM | #19 |
1455
Rep 1,487
05-10-2018, 01:16 PM | #20 | |
Rep 14
Thanks for the help. |
09-27-2019, 05:29 AM | #21 |
Rep 2
Is it possible for you to show which part of the cable is loose?
I have the same problem, but mine is F30 No valet switch as well. But all button and boot switch does not work. Only opens when I activated it from obd2 via workshop's computer. I'm dumbfounded. |
