BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding 256 GB USB issues
      04-30-2018, 02:36 PM   #1
hypephb
Drives: 2004 325Ci
256 GB USB issues
Hi Everyone-
This weekend I bought a 256 GB USB stick to play my music off of in the car. I tested it with a couple albums and it worked perfectly, so I loaded up my entire library (around 140 GB). When I put it in now though, I'm unable to scroll through cover view, search, or navigate it in any way other that manually going to each folder (tho that works perfectly fine). Everything is just greyed out.
Since I can see everything that way I assume it's not an issue with readability, is the car just taking time to process everything? Has anyone else run into this issue? Do I wait for it to resolve itself, or is there something I should do? Thanks for the help.
      05-01-2018, 03:36 PM   #2
dicky.hillary
dicky.hillary's Avatar
28
Drives: G30 520D SE
I've been having a similar issue.. I've got around 170Gb of music on a 500Gb drive... I've found that once you go above 120Gb it doesn't read correctly. This is annoying as the old f10 5 series was fine with the same drive and music collection. After a lot of poking and prodding at the dealer I was informed that it will only support up to 16,000 songs per usb drive... however the idrive supports up to 40,000 songs.
I'm currently arguing with my local dealer to do a full car software update, then I was going to ask the wider community for their thoughts etc. My gut feeling is this can be sorted by coding. After explaining that I'm a consultant storage / backup engineer at one of the largest IT companies in the world they finally stopped trying the bullshit answers that are used to fob off other customers. :-P
Would any of the gurus be able to comment please?
Rich
Current : 2022 G05 X45e
Previous : G30 520D SE / F10 520D SE / F31 320 M-Sport Touring / E92 320D SE Coupe
      05-01-2018, 08:40 PM   #3
forza1976
forza1976's Avatar
3397
Drives: BMW
2022 BMW M3X  [10.00]
I have a 64gb usb drive and it works perfect. 99% full. I’m guessing the bmw system cannot index that much music.
      05-02-2018, 01:27 AM   #4
dicky.hillary
28
Drives: G30 520D SE
Yeah that will be totally fine. I did a bit of checking when I was in the Dealership and found that iDrive 4 will work with any size drive and any amount of music, iDrive 5 & 6 seems to not like more than 120Gb. However, during my tests I found that the iDrive 6 does initially see all of the drive and all of the music, and you can select any songs etc. After about 2 minutes you get capped at 120Gb... but the song you selected that is from beyond 120Gb of data still works!
I personally think that they have coded a limitation in somewhere - but it is nothing to do with the size of the USB device, it will probably be more along the lines of the database files that retain the metadata for searching having a limit.
Oh and any device using FAT32 / exFAT / NTFS is fine. Mac formats it doesn't like.
Rich
5post
