"Rest" Button
06-11-2008, 01:45 PM | #1 |
210
Rep 2,110
"Rest" Button
Has anyone ever used this on the HVAC system? My CA was telling me about how you can keep the car warm in the winter or the car cool in the summer for a half hour when you run into the store or something. Anyone ever try this? I have pressed it a few times and it does not seem to work.
I know, I know, before anyone gets to it
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build Retired: 2008, 2011, 2013 328xi |
06-11-2008, 01:56 PM | #2 |
92
Rep 3,822
Drives: 2012 B8 S4 & 2013 F30 328xi
Yes I have and works quite well! Used in the winter but haven't yet for summer though.
'12 B8 S4 Ice Silver on Black/Premium/DSG/Sport Diff/Nav/Carbon Inlays/19' Titanium Wheels/RS4 Grill/AWE exhaust/Alu Kreuz/H&R OE/Pagid RS19
'13 F30 328xi Sapphire Black/Coral Red/Sportline/gloss black with matte red/Style 397 18" wheels gone: '07 E90 335i, Alpine White/Black with aluminum/sport/ steptronic/paddles/premium/Logic7 gone: '06 E61 530xi Sapphire Black/Black with aluminum/premium/panoramic sunroof/Logic7/PDC |
06-11-2008, 01:57 PM | #4 | |
57
Rep 1,019
Drives: Monaco Blue E92
'07 Monaco Blue 335i ordered 9/4 built 9/21 shipped 9/28 arrived 10/12 at dealership 10/18 vroom 10/19 christened 11/3... |
06-11-2008, 01:57 PM | #5 |
167
Rep 7,433
The outside temperature has to be within a certain range, and the engine has to be hot. Then you set the temps you want and hit rest and it will run the fan when the car is off. Works quite well in winter. I haven't used it in summer, I just open all the windows with the remote a few min I drive to cool it off.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
06-11-2008, 02:02 PM | #6 |
210
Rep 2,110
OK, so in the winter, just hit it before I turn the car off, and it should work then? Not sure why it was not working before at the beginning of April when I picked it up. Thanks guys.
06-11-2008, 02:05 PM | #8 |
57
Rep 1,019
No, after the car is off.
06-11-2008, 02:06 PM | #9 |
373
Rep 2,984
its the sleeper package.
"...I maybe drunk, but you're ugly, and I can sober up..." |
06-11-2008, 02:07 PM | #10 |
57
Rep 1,019
No it is standard, big round button on the right of the climate control console.
06-11-2008, 02:27 PM | #11 |
Rep 24
I can't see this working on a hot day. It would need to power the AC compressor in order to add much of a benefit.
I used this during the colder months and it worked well. |
06-11-2008, 02:31 PM | #12 |
21
Rep 437
The rest button only works to heat the car with residual engine heat. To cool the car, you need to set an internal timer (via iDrive in my car) to go off at at predetermined time, which will run for 1/2 hour. There are two separate timers, so you can set it to go off at two different times for half an hour each. Resets itself every 24 hours, so you would need to reprogram if you wanted it done another day. It is designed to pull hot air out of the car and try to equalize the interior temp with the exterior. It does not involve running the ac.
06-11-2008, 02:34 PM | #13 |
54
Rep 2,863
it's in the e9x package --- buy one and you get it.
06-11-2008, 02:35 PM | #14 | |
788
Rep 7,246
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
06-11-2008, 02:53 PM | #18 |
571
Rep 7,519
Drives: 2009 E90 335i MT
The REST button is to keep the cabin warm for a short period of time during the winter. It uses the residual heat from the engine and circulates the engine coolant through the heater. The function can be under the following conditions: within 15 minutes of the engine being switched off, the engine is at operating temperature, as long as battery voltage is sufficient, and the outside temperature is below 77°F/25°C.
The REST function will not cool the car. To do so the AC compressor would need to be running and this takes way too much energy from the battery since the engine would be turned off. For cars with iDrive there are the Parked Car Ventilation/Heating Timers. This function can be used at any outside temperature and provides forced air ventilation to the passenger compartment to lower the inside temperature towards the climate control setting. I think the name is rather misleading since the manual says nothing about actually heating but explicitly mentions lowering temperatures although I have no idea why anyone would want to lower the temperature inside the car during the winter. The manual indicates that this function has a high power consumption. There are two separate timers and each works for 30 minutes. You set them for when you want the ventilation to start. I use mine and set it for about ten minutes before my quiting time (and then end up having to work longer).
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
06-11-2008, 02:56 PM | #19 |
22
Rep 197
The temp outside needs to be 37 degrees or below for the feature to work.
2007 BMW E92 335i 6MT
Sparkling Graphite M6 Wheels 2008 Lexus IS-F Starfire Pearl |
06-11-2008, 02:56 PM | #20 |
571
Rep 7,519
It does not turn the AC on. But, yes, the timer only activates once per setting.
06-11-2008, 02:56 PM | #21 |
15
Rep 420
If you guys did, you would find that the Rest button is described under the heading "Using residual heat." This should be the first clue that the Rest button is not going to do jack in the summer to cool the car. The section reads as follows:
The heat stored in the engine is used to heat the passenger compartment, e.g., while stopped at a school to pick up a child. You can use this function for up to 15 minutes after switching off the engine if it is warm and the battery is sufficiently well charged. The outside temperature must be below 77 F/25 C (note: this is the second clue that this will not cool the car). The LED in the button comes on if these conditions are met and the function is activated. For this function to cool the car it would need to run the air conditioning compressor--something that won't happen with the engine off. So there.
1988 M5 Black/Natur (5/97-now)
2006 E90 330i Sparkling Graphite | Gray | Walnut | STEPTRONIC | ZSP | ZPP | ZCW | Navi | PDC | CA | sun shades (3/06-11/08) 2009 E90 335i Blue Water | Oyster | Walnut | STEPTRONIC | ZSP | ZPP | ZCW | Navi | PDC | CA | Logic 7 | 6FL/6NF | sun shades (12/08-now) |
06-11-2008, 02:58 PM | #22 |
15
Rep 420
Funny the pdf-based manual I have says 77 degrees. Thirty-seven degrees makes more sense. Need to check the paper manual in my car...
