04-20-2018, 03:17 PM | #1 |
Rep 7
Unichip-tec USB Carplay Activation for iDrive 4.2/5/6 NBT/NBT EVO
Hi,
Has anyone tested this from unichip-tec, http://www.unichip-tec.com/pd.jsp?id=16#_jcp=2 They claim instant activation of carplay for NBT EVO units with idrive 4.2 for $70 I have bought the solution (.bin file they provide using VIN/MAP info) but worried about installing it ;-) Any thoughts? |
04-24-2018, 10:12 AM | #2 |
123
Rep 565
AFAIK, the older head units will constantly reboot and hang when flashed to EVO because of its higher hardware requirements, which the older units don't meet (lower RAM for example).
EDIT: You can't activate CarPlay in a head unit with iDrive 4, it's missing hardware (WiFi) support. |
04-24-2018, 02:44 PM | #3 | |
1166
Rep 2,180
There are two kits in that link... one interrupts the OEM screen with a switchbox and the other seems to be a "USB" solution.
I want to see how they can integrate "OEM CarPlay" to a non-NBT EVO2 unit via USB without making the unit sick. Quote:
04-25-2018, 11:46 AM | #4 |
BimmerPost Supporting Vendor
668
Rep 1,980
Drives: 2020 G20 320i M Sport
If you have an ID4 NBT EVO, it will not work with the Unichip proxy kit or the USB solution. Your only option would be to replace the head unit with a full fledged ID5 unit but you will also gain the new interface along with wireless CarPlay.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
x-m4n148.00 |
05-02-2018, 03:56 PM | #6 |
725
Rep 1,615
But one would lose XM and BMW Services, correct? (been debating but when I heard XM and live wouldn't work, that to me is almost half the system lol)
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
05-03-2018, 05:54 AM | #7 | |
Coding ECU's remotely
448
Rep 1,180
Go to the Map screen, press the Option button on the iDrive controller, scroll to the bottom of the list and slect Navigation version - it will tell you which version of Nav you have - if it says EVO then you are all set and can just replace the headunit. HTH
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
05-03-2018, 07:09 AM | #8 | ||
725
Rep 1,615
EDIT: Just have NBT...
Wibbles447.50 |
10-06-2019, 02:59 AM | #9 | |
Rep 61
I also have the same ID4.2 Evo... i am looking for ID5 or 6... but i am afraid of loosing warranty? have you had any issues? do you keep your old HU? is straight swap working after the initial coding and fsc codes? Anything else needed other than the wifi antenna and the HU with ID 5/6 ? Thanks |
