F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > F30 335i M Sport Required Upgrades for HPDE Events
Extreme Powerhouse
      04-20-2018, 03:02 PM   #1
EstorilMSport
EstorilMSport's Avatar
84
Drives: 2014 335i M Sport
Hi everyone,
I recently purchased a 2014 335i M Sport and I'm looking to get into some track days at Sebring and want to know what suspension and brake upgrades I should be looking at to enjoy my time on the track.
I just installed Michelin PS4's and have the OEM M sport brakes and suspension (non-adaptive to my knowledge). Also I have an 8AT, does anyone track their auto F30? Any issues with overheating/heatsoak? I have an AA intercooler that is going on before any track time along with CP and DP and Stage 2 tune.
I should add that I have some track days under my belt in my previous cars: E92 335i (Sebring, Summit Point) and 981 Cayman S (Roebling Rd) but not a pro by any means. Thanks for the guidance.
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection
Taskmaster2465.00
      04-20-2018, 05:20 PM   #2
CJ421
CJ421's Avatar
1559
Drives: BMW M3
High-temp brake fluid should be all you need, you already got good tires. The 335i is quite capable. If you fade the brakes then the next upgrade would be pads, but OEM pads should hold up fine. GL!
Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      04-21-2018, 03:35 AM   #3
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
+1 on the brake fluid. I'm a big fan of the Motive bleeders, they work incredibly well.
Have fun and stay hydrated
Post up some pics/vids afterwards
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      04-22-2018, 12:52 PM   #4
EstorilMSport
84
Charles
What brake fluid would you recommend and should I go ahead and install stainless steel lines at the same time?
      04-22-2018, 01:02 PM   #5
rockymtnpilot
74
Drives: 2017 BMW 340i
You can pick up something worthwhile at AutoZone. Limfac for the m sport is the pads
2017 340i xDrive
MPPSK
More to come
      04-23-2018, 07:11 AM   #6
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
I have used bmw OEM OR ATE SL.6 at VIR a few times with no issues.
      04-24-2018, 09:08 AM   #7
CJ421
CJ421's Avatar
1559
Drives: BMW M3
Ask a BMW-specific shop that works on race cars what they recommend. Turner or VAC are two shops. But basic high-temperature fluid should be fine.
It's not like your car won't work on-track with the standard BMW brake fluid. It just won't have the temperature threshold; the limitations of the brakes wouldn't be as high. E.g. you might have to take a cool-down lap now and then to let the brakes cool off.
Charles
      05-29-2018, 08:53 PM   #8
tsbrown
tsbrown's Avatar
1038
Drives: 2019 540i M Sport
I used mostly Motul 660 fluid on my old E90 M3 for CCA HPDEs and worked well. Car always ran on Michelin PS2 or PSS, whichever was newest available at the time, and stock pads first, then PFC Z-rated pads after that. I've not tracked my F30 340i/6MT. Have fun!
      09-27-2018, 07:05 PM   #9
EstorilMSport
84
Bumping an old thread here but I’ve since installed a set of coilovers and looking to swap out my brake fluid. Does anyone know how much brake fluid is needed to flush the full system? Also any recommendations on bleeder systems to make the job easy? Thinking about picking this up https://www.ecstuning.com/b-schwaben.../007237sch01a/
      09-28-2018, 11:41 PM   #10
sewhelan9
sewhelan9's Avatar
35
Drives: 2018 440i Gran Coupe
I used 3 bottles of Motul RBF600 in my recent brake fluid flush and that seemed to be the right amount. I also have that Schwaben brake bleeder and it worked fantastic, better than the Motive one a friend of mine has IMHO.
2018 440i Gran Coupe (F36), Glacier Silver/Black Dakota, M Performance and Track Handling Package, MHD Stage 2 and xHP Stage 3 flash tunes, Dinan Shockware and mid-pipe, HJS high-flow cat, AP Intake, RW Carbon duck bill spoiler and rear diffuser
EDWYER1674.00
      09-30-2018, 07:16 PM   #11
zinner
zinner's Avatar
559
I used Motul 600 and Powerstop Sport pads this weekend at the track and they were great. Using the 4/2 pot msport brakes.
      01-06-2019, 07:58 PM   #12
Big boi m5
No_Country
322
Drives: 135i
I bought whatever the best pads and rotors are from BMW and they worked extremely well. No brake fade at all at Road America.
Expensive though.
I wouldn't bother switching if you have some pad left though
      03-26-2019, 06:27 PM   #13
EstorilMSport
84
So I finally got around to doing a track day at Sebring this past weekend. For prep I flushed the fluid with fresh RBF600 and took the PS4S tires down to 30 psi. I also installed the BMS oil cooler valve.
The car held up great and the suspension was awesome. I ran in Sport + with the bootmod3 Stg 2 93 octane tune and never ran into overheating issues in 78 degree weather. I did get some brake fade eventually (running stock M sport pads). I did have a little bit of a hard time with the throttle modulation as the tune makes the pedal very sensitive to input.
For my next track day I'd like to swap brake pads. What pads should I run and should I swap the rotors as well (40k on them now) along with SS brake lines? Also has anyone installed F/R sway bars?
Thanks for the advice. Definitely more of these in my future.
      03-27-2019, 01:01 PM   #14
brigade24
brigade24's Avatar
156
Drives: 2013 335 X-dive
ive gotta dinan sway bars in my car...pricey but they work well and they are 3-way adjustable. I autox a 2013 335xi 6MT and these bars are very well balanced...
I have heard some other after market bars breaking the front mounts on the shock towers because they are too stiff...something to watch for.
if you've got the electronic damping setup, there might be a tune for your car...i would explore this option before changing the bars which require dropping the subframes (both front and rear)
      03-27-2019, 06:16 PM   #15
EstorilMSport
84
Thanks for the feedback. What suspension are you running? I’m on KW Clubsports (no-EDC). I’m an 8AT but running stage 2 software on it.
      03-27-2019, 09:11 PM   #16
brigade24
brigade24's Avatar
156
Thanks for the feedback. What suspension are you running? I’m on KW Clubsports (no-EDC). I’m an 8AT but running stage 3 software on it.
Thats a good setup...ive got a friend who is running the KW Clubs and he raves about them....I was looking at the Bilstein club sports but decided against it.
I'm running bc racing coilovers with swift springs. I wanted to preserve the factory motion frequency (flat ride) but take away some of the roll for better reaction time so I've got 7kg/mm (392lbs/in) springs up front and and 20kg/mm (1120lbs/in) springs in the back...
Ive got camber plates too which gets me around -2.9 deg of camber...that's not enough for national level autox competitions so trying to find more.
I am going to eventually get my shocks revalved to improve the compression and rebound characteristics.
      03-28-2019, 09:56 PM   #17
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
Thanks for the feedback. What suspension are you running? I'm on KW Clubsports (no-EDC). I'm an 8AT but running stage 3 software on it.
They didn't do the revalving when you opted for swift springs?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
      03-29-2019, 12:28 AM   #18
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
I ran stoptech sport pads and I was not able to make them fade, no matter how hard I drove (to be honest, the track I was on wasn't too big and we had 3 hard braking points, with 1 of them at the end of a long straight) I found these pads to be the perfect balance between street and track. I would swap in SS lines as well if you're going to be tracking regularly, the rotors could probably go another 10k, but if you're going to swap everything, might as well get new rotors too.
My next step was going to be sway bars, but unfortunately I had alot of maintenance to catch up on, I was looking to get the hotchkis sway bar set.
P.S:
Follow the yellow around the track and that's the track, it's pretty small, but it'll test your brakes.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
      03-29-2019, 11:57 AM   #19
brigade24
brigade24's Avatar
156
There were a couple of issues, I would have had to wait an additional 6 weeks for the swift/bc racing combo. Being in the middle of the season, i opted to drive around the issue using the stiffest BC springs they had (only in the rear...the fronts were 6kg/mm) and order the swift springs and do the revalve at a later date.
the swift springs used by BC racing have a custom ID of 62mm. Anyone can easily procure 60mm or 65mm, but 62mm? a bit more challenging. And of course, since this is a custom bc swift spring...they come with a custom bc price! And I was like...nope.
FWIW, the Swift springs are Superior in every way. They don't sag and the resulting ride quality is excellent...I just could not justify paying the premium for the I.D.
f30post
