BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis 648M 7-series wheels on a G30
      04-15-2018, 11:04 PM   #1
SteveMondragon
Seaman
SteveMondragon's Avatar
69
Drives: E92 | I01 | G30
I know people have already done this, but nobody really posted any good 'side profile' pics of the car to show the offset of the wheels on a G30 chassis.
I had originally left on the 15mm spacers when I used them on my rear 664M wheels, but they push the 648M wheels out too far past the fender and looks a little ridiculous. With no spacers, the 648M wheels sit perfectly flush on the car and looks really good.
Handling at freeway speeds is great, better than the square 648M wheels I had on. Plus, the 275 rears look beefy & aggressive .
Appreciate 4
nsa100185.00
omg61872.00
TopgearLA119.50
      04-16-2018, 01:25 PM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Looks great!
5 or 7 Series tire sizes?
      04-16-2018, 07:19 PM   #3
omg618
72
Drives: MB E350 D / MB GLE / BMW M5
Looks great. More PICS!!!
      04-16-2018, 09:44 PM   #4
SteveMondragon
Seaman
69
They're 20" tires that fit both the 5-series and 7-series wheels.... 245/40-20 and 275/35-20. Same size as what you find on the 20" 759i and 669M wheels, which are an available option on the G30 5-series. Difference is the offset of the wheels.
Thanks. I posted more pictures in the DGM thread in the Photos forum.
clee1982797.50
      04-16-2018, 11:27 PM   #5
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Thanks!
Those are the OEM tire sizes for 7 Series G11/G12. The 5 Series G30/G31 use tires with 1" shorter overall diameter, ie 245/35-20 front and 275/30-20 rear.
G30/G31: 245/35-20, 680 mm
G11/G12: 245/40-20, 704 mm (3.5% taller)
G30/G31: 275/30-20, 674 mm
G11/G12: 275/35-20, 700 mm (3.9% taller)
The result when using 7 Series tires on 5 Series is that the car sits 1/2" higher from the ground, the wheel gap is reduced by 1/2", the speedo reads about 4% lower than with OEM tires and the odometer accumulates 4% less miles than you actually driven.
Taller tires will also increase comfort, and affect both acceleration and fuel consumption.
I am sure you are aware of all this, but it could be good info for other people reading this thread.
Appreciate 6
      04-17-2018, 07:47 PM   #6
AlphaOmega4
433
Drives: YMB M4
SteveMondragon
What Rear spoiler do you have ? Looks Great !!
Thanks
In all your ways acknowledge Him, And He shall direct your paths.
      04-25-2018, 11:20 PM   #7
SteveMondragon
Seaman
69
Originally Posted by AlphaOmega4 View Post
SteveMondragon
@AlphaOmega4
Sorry, didn't see this until now.
It's a G30 M5 replica painted spoiler. Pretty much the same size & shape as the factory carbon fiber trunk spoiler. The fitment is perfect and the color matches perfectly.
      04-30-2018, 10:34 PM   #8
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
Two more shots of 648M
Appreciate 3
      12-18-2018, 11:40 AM   #9
fan51
fan51's Avatar
No_Country
280
Drives: F90 M5
Maybe you can help. I'm also looking to run 245/40-20 and 275/35-20 tires on my new wheels. The offset is ET36 and ET 25. They're an aggressive offset.. I specifically asked for an aggressive setup because I like a flush look with the fenders. However now I'm worried the tires might be too tall and will cause rubbing issues. Maybe rubbing with the fender/quarter panels, or maybe with the control arms, struts, etc..
Any advice is appreciated. Thank you!
      12-21-2018, 05:43 PM   #10
Sarang5
Drives: 530e
Just bought some 20" 648m's for my 2018 530e. Look and drive great. Raised the overall car about 1/2". I used to have H&R springs and spacers on the stock 18", but took them off before I bought the 20's. They bottomed out a bit too much. Do you guys think putting them back on would bottom out with the 20's?
      12-24-2018, 10:45 PM   #11
bmwmike01
Drives: 19 M550 (on order
Thanks!
G11/G12: 275/30-20, 700 mm (3.9% taller)
Hey, I listened to your advice and got the +5 on the side wall for my 668m rims. It's been good so far thanks! What do you mean affect acceleration and fuel economy, would this be in a positive way or negative way?
      12-25-2018, 05:23 AM   #12
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Taller and heavier tires will decrease the acceleration at low speed due to tall gearing.
Tall gearing (from taller tires) can on the other hand be beneficial for fuel economy. Lower engine speed for a given vehicle speed.
      01-04-2019, 07:57 AM   #13
mobilejo
mobilejo's Avatar
1113
Drives: G06 X6 40i
I took the plunge on some 648's - I used standard G30 tyre sizes (245/35 275/30) to keep everything the same as before. I had 759i wheels previously so these are a touch lighter (1kg per wheel), plus it meant I could remove my spacers as. I'm very happy with the look and feel.
clee1982797.50
      01-04-2019, 11:41 AM   #14
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Yes, the fitment is great for G30!
That's how it usually is, 7 Series wheels fits great on 5 Series and 5 Series wheels fits great on 3 Series.
The OEM fitments are too conservative!
      01-11-2019, 10:44 AM   #15
Sslebi
Drives: BMW G30
Look great! Are those 5 o 7 series tires?
      05-30-2019, 12:04 PM   #16
Scitation
Drives: BMW M550i
Hey man do you have more pictures of the fitment? I just purchased these wheels for my G30 and I’m trying to figure out what tire sizes to go with. Looks awesome!
clee1982797.50
      05-30-2019, 04:09 PM   #17
VirtualGuitars
VirtualGuitars's Avatar
7861
Drives: 2024 BMW XM Label
The 759i wheels on my M550i came with the following sized tires:
Front: 245/35R20 Fr Run-Flat
Rear: 275/30R20 Rr Run-Flat
      06-16-2019, 09:31 AM   #18
SteveMondragon
Seaman
69
Since my original post, I’ve switched the tires out since they eventually wore out, but never had an issue with the original setup.
I’m now running the following setup below, and the stance looks super aggressive and good on the car. Fitment is good and no issues with any rubbing. Price was actually a few bucks cheaper too than going with traditional 245 fronts and 275 rears. The 648M wheels are wide enough to accommodate the tires.
Front: 255/35R20 P-Zero Sport non-RFT
Rear: 295/30R20 P-Zero Sport non-RFT
      07-04-2019, 05:55 AM   #19
wfydaniel
wfydaniel's Avatar
China
112
Drives: G30 540i + G82 M4C Xdrive
I put oem 706m on my g30 540i . They actually look fine to me
BMW Product Owner @Beijing R&D Center
G30 540i Bluestone
G82 M4C Xdrive IoMG / YMB
Golf 7.5 280tsi White
      07-05-2019, 02:30 PM   #20
KnightedBMW
2347
Drives: 2022 M3C
Any pics of them on your actual car instead of on the M5?
@bg_g80m3
      07-06-2019, 12:13 PM   #21
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I guess that's his 540i, looking like a M5.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
wfydaniel111.50
      07-08-2019, 08:53 AM   #22
wfydaniel
wfydaniel's Avatar
China
112
😂 you're right . It's my 540i with an M5 bodykit . You can pay attention to the sun roof
G30 540i Bluestone
5post
