04-11-2018, 02:07 PM | #1 |
279
Rep 689
A Pillar Pass Side
good afternoon, is it OK and Safe to route a dash cam cable thru the upper joint of the A Pillar above the airbag tag? will it in anyway damage the panel, airbag or anything behind it, etc. if I stuff in the cable at that spot in the crease? thanks.
Pic attached to clarify what I am referring to... http://f30.bimmerpost.com/forums/att...1&d=1523474336 Last edited by BMW11; 04-11-2018 at 02:20 PM.. |
04-20-2018, 08:10 PM | #2 |
279
Rep 689
Does anyone know if its safe to tuck wires from dash cam in to the crease in the A Pillar as shown above in the picture? I am concerned that if I put cables in there; will it effect airbag deployment or anything else. Thanks
04-23-2018, 09:19 PM | #6 |
35
Rep 83
I didn't need to remove mine when I was hard wiring my radar detector. Instead I pulled back the door weatherstripping, ran the wire across the top of the A pillar trim and down the side along the door and then pushed the weather stripping back into place.
BMW11279.00 |
04-24-2018, 12:14 PM | #8 |
83
Rep 348
I didn't pull it off as it was not required. I just used a trim tool to lift the trim slightly (fingers would work too) and wedge the wire in slowly. Unless the wire is massive, I don't see a problem with just slipping it in. If you don't have a trim tool, I think it's easier to start at the door seal/weather trim, just pull the door trim out enough so you have space to work and lift the bottom piece of the A pillar a bit while pushing in the top slightly. There is a very tight spot close to the middle but it will go through as it is not interlocked there.
BMW11279.00 |
04-26-2018, 02:29 PM | #9 | |
42
Rep 16
Deleted-User73.50 |
04-27-2018, 07:48 AM | #10 |
13
Rep 92
I'm after doing the same and I'm sure I read that the airbag is in the form or a curtain from the B pillar and not in the A pillar. I'm new to the car so I'd check to be 100%
