All windows rolled down and sunroof open?
04-08-2018, 10:29 PM | #1 |
Rep 37
Came out in the rain to find all my windows rolled down and my sunroof wide open. In the rain. What the hell could cause this?
I went into a restaurant with my wife, we both looked at the car as we were walking away from it as we were debating the parking job. Windows were definitely up. Came back and all windows were down and sunroof was wide open, in the rain. This is the 2nd time this has happened, do I have an electronic issue? How do I fix or prevent this? This is a huge problem as I park on the street in an area where it rains very very often. |
04-08-2018, 11:35 PM | #4 |
154
Rep 342
Drives: 2008 E90 335i; 2016 F80 M3
I'm pretty sure you can code that feature off but not sure what you need to do so. I coded my car when I did the Alpina TCU flash, but was a dude from the forums and he did remotely.....so, can't help much on that end.
04-09-2018, 03:32 AM | #6 | |
458
Rep 2,755
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
tlow982191.00 |
04-09-2018, 08:46 AM | #7 |
Rep 37
Well dang, sure enough I hold down the button and the window went down. Now I'm going to be all paranoid about it until I can find a way to eliminate it. What a terrible feature. Time to go buy some leather conditioner.
04-09-2018, 09:09 AM | #8 |
118
Rep 272
What kills me on this feature is how awfully unpredictable the range is to enable it. I can be working in the yard and come out and see all windows down and sunroof open, even though I'm not going anywhere. Counter that to walking up to the car to leave, and I've got to be within 4 ft of the car to get this to work.
One solution may be a key cover for the OP., to physically cover the unlock button. |
04-09-2018, 10:43 AM | #9 |
157
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
Some people put their key in a case. I used to accidentally press the trunk button on my old car which was a problem because the springs were strong enough to open it all the way.
You could disable it with feature coding if you don't use it/want it.
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
04-09-2018, 06:16 PM | #11 | |
1436
Rep 2,526
Drives: 2011 328i Wagon
But sucks if you sit on the key and open the windows - yeah, I've done it once or twice, the range is longer than you might think, especially when the battery is fresh. You can also code it to close the windows by holding down the lock button.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
tlow982191.00 |
