04-05-2018, 09:29 AM | #1 |
63
Rep 580
Drives: G20 M340i
N20 Maintenance at 100K - oil filter housing gasket
Surprise, another oil filter housing gasket "seeping". Does anyone have a DIY for the housing gasket on an N20? I've looked and cannot find one. I'm guessing it's similar to N55 but different. The vehicle is actually a 2015 X3 but I'm posting here because I figured I might get more responses. Also, any other recommended maintenance at this mileage. Took it in for a vehicle check and was shocked that nothing was recommended other than doing the ofhg, not even plugs and I'm pretty sure they've never been changed.
Thanks!
04-05-2018, 10:05 AM | #2 | |
1032
Rep 2,382
https://www.newtis.info/tisv2/a/en/f...lines/HjUoZjgW
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-05-2018, 12:39 PM | #3 |
481
Rep 1,572
Are you sure it's the gasket and not a cracked housing. Is your oil slightly grey or milky looking? If you still have the original plastic housing, that has been a failure point. see: https://bmwtechnician.com/2015/12/15...ousing-update/ Also there appears to be a SIB issued against the plastic housing: N20/N26 plastic oil filter housing recall SIB 11 13 15 I don' know the range of the vehicles affected or the actual text of the SIB, but the dealer will: http://www.bimmerfest.com/forums/sho...d.php?t=951692 As you still under warranty?
04-19-2018, 12:52 PM | #4 | |
63
Rep 580
Drives: G20 M340i
04-19-2018, 12:53 PM | #5 | |
63
Rep 580
Drives: G20 M340i
Luckily ours was made after they fixed that brilliant engineering decision.
