04-03-2018, 01:32 PM | #1 |
BMW obsessed
9578
Rep 10,874
IND | F90 M5 Painted Center Grille Trim | Installation Procedure
Step 1: Pull the hood release lever twice to unlatch the hood. Subsequently, raise it up to gain access to the front grille tabs. Step 2: Use a pick tool to depress the three tabs along the top of the front grille. Afterwards, pull the grille towards you with uniform pressure to remove it. For night vision cars, please pull gently and remove the connectors / clamp the hose. Repeat on the other side. Step 3: With both grilles removed, use a pick tool to gently release the center grille trim working from top to bottom. There are tabs on each side. Step 4: To fully remove the center grille trim, gently pull the bumper extension towards you. This will free up space for the grille trim to move freely. Step 5: Installation of the iND painted center grille trim is simply a reverse procedure of the removal. Start by inserting the piece into the bumper and pushing the clips into place working upward with uniform pressure. Step 6 : With the center grille trim properly installed, snap the front grille set into place with uniform pressure. For night-vision owners, re-install the connections and remove the hose clamp.
04-03-2018, 02:34 PM | #2 |
1716
Rep 1,909
Drives: 2023 M5C
For some reason I was thinking there were sensors behind that middle piece... That looks so much better!
05-04-2018, 08:57 AM | #4 |
BMW obsessed
9578
Rep 10,874
We currently do not have any carbon grilles on our site. However any carbon you see for the F90 M5 on our site is genuine BMW.
05-11-2018, 09:33 AM | #6 |
97
Rep 254
Of all cosmetic items, the painted center grille piece looks to be the most mandatory, regardless if you have chrome or black grilles. That center piece makes a huge difference!
Mildred:
2006 M5 E60 Indianapolis Red/Sepang/Piano Black *R.I.P.* |
05-15-2018, 03:18 PM | #7 |
Not a BMW Genius
48
Rep 118
IND
Will the front piece with the hole for the camera affect the camera/focus at all? Will it need to be calibrated as what happens to most sensors on bodywork on most luxury cars now. Basically any issues with the substitution?
05-15-2018, 03:42 PM | #8 |
BMW obsessed
9578
Rep 10,874
It will not as the camera is not touched for the install. Only the cover gets replaced.
05-31-2018, 09:18 PM | #9 |
51
Rep 335
This will be my first mod for sure. I am not sure what BMW was thinking with the black piece for all cars.
2016 Tesla Model S P100D
2016 Porsche GT4 2017 MB AMG C63A 2018 M5 - maybe next |
06-01-2018, 11:20 AM | #10 |
1716
Rep 1,909
Drives: 2023 M5C
Curious how a piece like this gets priced/painted when someone with an individual paint or better yet, the Pure Metal Silver paint job wants one.
06-12-2018, 02:33 PM | #11 |
BMW obsessed
9578
Rep 10,874
Individual paint for the most part is no problem as we have most of the colors saved over the years.
06-18-2018, 10:17 AM | #12 |
168
Rep 454
Installed IND painted center grill trim, IND black grill, and front reflectors over the weekend. I think the painted center grill trim and front reflectors are a must for the M5.
Now I just need the Acexxon rear reflector... |
IND-Distribution9578.00 |
07-18-2018, 09:59 AM | #14 |
Not a BMW Genius
48
Rep 118
Where can I get that specific pick tool? Also, the hood lip hang over, what's up with that? Would much rather it be flush.
09-07-2018, 11:45 AM | #15 |
Not a BMW Genius
48
Rep 118
Are the pieces without the hole for cars that didn't get the safety option or does this camera have to do with the night vision. Want to pre-order before my car arrives. Thanks.
09-10-2018, 12:26 PM | #16 | |
BMW obsessed
9578
Rep 10,874
basque7648.00 |
09-10-2018, 07:38 PM | #17 |
23
Rep 54
Drives: 2018 M5
