TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Lowering problems
      03-31-2018, 05:14 PM   #1
Ander335xi
Ander335xi's Avatar
Drives: Bmw e91 335xi n54
Lowering problems
Hi eveyone,
I'm new to the forum, my name is Ander and I'm from the Basque country. I have a BMW 335xi E91 from 2007. I hope you can help me. I want to lower the height of the car with specific H&R sport springs for the xdrive. people tell me that front driveshafts are going to suffer a lot and they are going to break easily. Did you have any problem with lowering the car?
Thank you all!!
      04-01-2018, 10:38 AM   #2
Mistajay
Mistajay's Avatar
29
Drives: 335i
i do it for more than 140 000km an no problem in winter track and every crap you can do with a car i do it...
If you buy H&R buy good strut with it. I run it like 1 month with oem and strut and it was the baddest idea i got... LOL
      04-01-2018, 11:31 AM   #3
Ander335xi
Ander335xi's Avatar
I'm glad to know that I can lower the car with no risk. My idea to use the original struts, but in a while change them for blistein b8.
Thanks for your advice and help !!
      04-01-2018, 11:41 AM   #4
Mistajay
Mistajay's Avatar
29
Drives: 335i
Do it directly for the B8
But if you want to keep good comfort with your car go a head with KW v1.
      04-01-2018, 12:22 PM   #5
Ander335xi
Ander335xi's Avatar
If i use m3 e92 original struts?
Are they compatible with my car? a friend has the suspension saved because he changed it to his m3.
      04-01-2018, 01:09 PM   #6
Mistajay
Mistajay's Avatar
29
Drives: 335i
You have an Xdrive its not compatible at front at not at rear too you need to change the lower table.
      04-01-2018, 06:34 PM   #7
Ander335xi
Ander335xi's Avatar
perfect, thanks for the clarification and your great help! at the moment I will install the h&r with the original struts and if I'm not convinced with the result, I will put the b8
Thanks again!!
