03-31-2018, 12:58 AM | #1 |
97
Rep 254
Drives: 2019 Black 330i xDrive
Hey guys,
I got a warning that my DEF active tank wasn't holding the right amount of pressure. I took it in to the dealership and they lifted it up and found out that the passive tank was smashed while hitting a pothole a couple months ago. Now two days ago my 1000 mile warning popped up and the dealership said my car will stop running afterwards. Is there any way to code this via esys or ISTA without replacing the part right now? The procedure is relatively easy and I can do the repair myself, but in Michigan its not warm enough yet and I don't have a garage at all. I just need to get rid of the warnings and ignore the sensor until it gets warm enough to repair it. The dealership wants $450 in labor for a simple procedure. Thanks!
2019 G20 Black 330i xDrive
03-31-2018, 09:51 AM | #2 |
3572
Rep 10,352
No. It's against federal law to disable emissions system so BMW won't provide the ability to code it out. When you run out of DEF the car will not start. Can you fill the active tank seperately?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
03-31-2018, 10:12 AM | #3 |
Curmudgeon and Pedant
690
Rep 3,489
I'll reply here rather than in diesel subforum since you already got an answer...
http://www.realoem.com/bmw/enUS/show...diagId=16_0914 If you look at the diagram, you need to plug the line #5 so that you can then fill only the active tank. The active tank is on the right IIRC, behind the rear wheel, passive tank on left. Not sure what the price for the passive tank is - probably $400-$500 range. |
03-31-2018, 04:00 PM | #4 | |
97
Rep 254
03-31-2018, 09:03 PM | #5 | |
690
Rep 3,489
There is more info in the E90 and F30 diesel forums. Look for AARodriguez posts. |
03-31-2018, 10:54 PM | #6 | ||
97
Rep 254
04-02-2018, 09:03 PM | #7 | |||
3572
Rep 10,352
04-03-2018, 09:27 PM | #8 | ||||
97
Rep 254
