BMW M5 F90 (2018+) General Forums Cosmetic Modifications    IND | F90 M5 Painted Hood Roundel | Installation Procedure
      03-29-2018, 12:29 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Step 1: Apply a solid ring of painters tape around the hood roundel to create a barrier between the paint and factory unit.
Step 2: Use the supplied piece of fishing line to work your way around the circumference of the roundel. This will break the adhesion of the double sided tape that secures the roundel.
Step 3: Carefully pull up the roundel to release it from its retaining tabs. You may use a bondo spreader to help pop it free. Keep the factory grommets in place to re-use them.
Step 4. Clean the residue from the OE double-sided tape with a clean cloth and adhesive remover. Ensure the area is clean and dry before installing the IND hood roundel.
Step 5: After discarding the ring of painters tape from the hood, expose the double-sided tape on the IND roundel and, with uniform pressure, press the new piece into place.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      03-29-2018, 11:47 PM   #2
neohh
168
Drives: F90 M5
how about black or CF kidney grill?
      03-30-2018, 08:52 AM   #3
IND-Distribution
BMW obsessed
9587
We should have them ready within a couple of weeks, if not sooner.
Appreciate 2
neohh168.00
      04-06-2018, 09:03 PM   #4
stbm5
261
Drives: 2018 M5 DG
can you post up pics of your painted roundels? close up of each, the matte, gloss and black chrome? maybe even side by side with standard roundel...
thanks
      04-07-2018, 04:22 PM   #5
IND-Distribution
BMW obsessed
9587
thanks
Hope this helps.
Matte Black, Gloss Black, and Black Chrome
      04-07-2018, 05:05 PM   #6
stbm5
261
Drives: 2018 M5 DG
thank you!
      06-27-2018, 12:42 AM   #7
drewzMMM
drewzMMM's Avatar
97
Drives: Future M5 F90 Owner
Such subtle differences between each roundel...
Mildred:
2006 M5 E60
Indianapolis Red/Sepang/Piano Black
*R.I.P.*
      08-08-2018, 04:03 PM   #8
IND-Distribution
BMW obsessed
9587
It is more pronounced in person however gloss black is the most popular.
      10-25-2018, 09:16 PM   #9
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Is the front or the rear roundel larger? I ordered both the hood and trunk painted roundels, but the larger one doesn't have any adhesive on the back of it...
m5post
