03-26-2018, 08:34 PM | #1 |
19
Rep 83
BMW Resurfaced Rotors.
Hello guys took my car in for service.
Oil Changed. Rear Pads changed. Rear Rotors Resurfaced ? Wasn't it advised against rotor resurfacing for BMW ? The dealership resurfaced my rotors in the back. What is the minimum thickness for a f30 before they have to replace them ? Car pulsates while braking now it got better after driving a few miles on the new pads is this normal ? |
03-27-2018, 04:17 AM | #2 |
No 55mph
1622
Rep 8,476
Didn't know anyone resurfaced rotors any more - so 70's
Especially the dealer, think they would want to sell you new rotors. Even while my car is under warranty they totally replaced the rotors with new Even when I'm paying I would buy new rotors instead of resurface, but hey, if done correctly there should be no pulsation You might get some pulsation when pairing new pads with old rotor until the pads 'wear in' but should be nothing with new rotors or correctly resurfaced versions...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-27-2018, 12:37 PM | #4 |
No 55mph
1622
Rep 8,476
Well, all I can say is whenever my pads were changed under maintenance plan - they also installed new rotors & I didn't have to ask for them
I would definitely inquire, guess it's possible for different dealers to have different policies...
03-27-2018, 03:17 PM | #5 |
481
Rep 1,572
That is odd. BMW dealerships that I've used have ALWAYS installed new rotors and pads as a set when needed under my maintenance plans. I'm surprised the dealer service department even had a Brake Lathe or anyone trained in using it properly anymore. Hopefully, this wasn't your technican for the brake work.
Unless the rotors are almost new, its cheaper in parts, labor and customer satisfaction to change rotors and pads. Too much of a hassle otherwise. I'd be very curious as to why they turned your rotors and what the final thickness measurement was after turning. Depending, you may "run out of rotor" before the pads are close to being due for replacement. Last edited by Orion4; 03-27-2018 at 03:26 PM.. Reason: added detail |
Tribalpinoy91193.00 |
04-01-2018, 09:17 PM | #7 |
172
Rep 740
The dealer cut the front rotors on my f15 before because it was warped.
Check this out... https://bmwtechnician.com/2017/04/12/bmw-brake-lathe/
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
illusionx18.50 |
04-07-2018, 02:38 PM | #8 |
zzzzaaaaannnnggggg
24
Rep 120
I used to always get the rotors changed but last time the dealership told me BMW is telling them to now resurface first before replacing.. /shrug
_./ 2014 328i xDrive, Alpine White, Coral Red Interior, M-Sport Conversion (from Sportline), 15% Tint, Trunk Spoiler, Roof Spoiler, Active Autowerke Exhaust, Gloss Black Double Slat Grills, DINANTRONICS Sport, VMR V801 Wheels \_.
04-07-2018, 02:51 PM | #9 |
481
Rep 1,572
Looks like BMW is trying to go the "cheap" route with rotors under the Maint. plans
04-10-2018, 10:59 AM | #10 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
I helped a friend swap rotors/pads on his 435i the other weekend and he told me the first time his brakes were changed by the dealer under the free maintenance plan they resurfaced the rotors too and changed the pads.
illusionx18.50 |
04-26-2018, 08:31 AM | #13 |
8245
Rep 16,088
If the rotors can be resurfaced without taking them too thin, and if the dealer has a lathe, that's what they'll usually do. If they don't have a lathe they'll probably replace rather than re-face. The idea that you can't turn rotors can be traced to Japanese cars, which typically use rotors that are too thin to be turned, to reduce weight.
05-09-2018, 06:24 AM | #15 |
3575
Rep 10,355
I just found out that dealers have access to a portable lathe which turns the rotors while they're still attached to the car.
BMW uses it for in-warranty brake issues.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
illusionx18.50 |
05-11-2018, 07:27 PM | #16 |
4517
Rep 8,942
New bmw official policy is resurface if possible for brake service. New rotors only if absolutely necessary.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
05-17-2018, 09:44 PM | #17 |
1455
Rep 1,487
Drives: 2108 X3 xDrive30i
I thought they stopped resurfacing rotors about 10 years ago...Am I wrong here?
05-20-2018, 02:00 PM | #18 |
126
Rep 424
I thought so too. Yesterday got my car back from the dealership and they replaced the pads and turned the rotors. Love that it was free work done so I can't complain but it looks like they started turning them again after the free maintenance came around.
05-27-2018, 12:20 PM | #19 |
8245
Rep 16,088
To quote myself, The idea that you can't turn rotors can be traced to Japanese cars, which typically use rotors that are too thin to be turned, to reduce weight.
05-29-2018, 09:57 PM | #20 | |
102
Rep 343
could you explain how? |
