03-25-2018, 10:37 AM | #1 |
45
Rep 103
Track Alignment?
I have just installed GC front camber plates, 18x9.5 wheels all around with RE-71r tires so it is alignment time for track day use. What specs should I have the car set to front and rear?
03-27-2018, 05:53 PM | #2 |
1622
Rep 3,402
I'm not an expert so I can't help but I just read a thread here that talks extensively about your exact question. Take a look at the Camber Plates thread just below. They talked about 2.75 being the sweet spot with your tires.
03-30-2018, 03:02 PM | #3 |
197
Rep 155
What springs/rates are you running? Mine are 350/650lb, square 265 setup, -3.2/-2.2, 0 toe front, 0.18 toe-in on each rear.
Seems to drive well? The rear end rotates well.
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
07-24-2018, 10:17 AM | #5 |
Life is on the Track, the rest is just waiting.
381
Rep 731
I am considering this set-up for my car. What size tires are you running? Stock suspension?
