Water Pump status from Inpa
03-25-2018, 07:37 AM | #1 |
1007
Rep 2,243
Drives: 2007 328i / 2014 M235i
How do I interpret these results? Specifically, the temps look okay, what does the % 'status water pump' mean?
I did not see the rpm Also what do the other buttons do. The 5, 50, 95 gave me a Actung.. blah blah blah error. The DME button said activating or something like that. The F5 button looked like a calibration or priming operation so I didn't progress further. Thanks |
03-25-2018, 11:39 AM | #2 |
185
Rep 1,017
That the percentage at which the pump is running at that moment. The low temp,is keeping the pump from working higher than needed, it goes up then temp rises
03-25-2018, 03:03 PM | #4 |
Art Collector
2427
Rep 3,450
You can't. At least not that I've ever seen...
I'm not sure what data would be able to quantify pump health anyway. In my experience, until there is an issue with the pump, you won't get any codes or indications of a fault. For that reason, it's essentially a binary thing: it's either working correctly, or it's not. |
03-25-2018, 03:43 PM | #5 |
1007
Rep 2,109
I remember reading there are some hidden codes (not throwing light on) related to water pump that usually come on before it completely fails. They were something like "water pump speed is not what computer told it to be". Search for "water pump code" posted by Eftreeoh.
03-25-2018, 03:52 PM | #6 |
1007
Rep 2,109
From this post, which copies a TSB on cooling issues:
http://www.e90post.com/forums/showthread.php?t=601250 FC 2E81 Electric coolant pump, speed deviation, speed outside the tolerance FC 2E82 Electric coolant pump cutoff, over-current FC 2E83 Electric coolant pump, power-reduced operation, dry run FC 2E84 Electric coolant pump, communication FC 2E85 Electric coolant pump, communication, no voltage at emergency operation input of pump |
03-25-2018, 04:16 PM | #7 | |
242
Rep 1,354
I noticed the jet engine roar once two weeks before the pump failed, and scanned for codes including hidden codes... nothing. Only after the pump failed were codes thrown. If you are lucky a code may be thrown, but that was not my experience. |
03-25-2018, 04:57 PM | #8 |
65
Rep 218
Maybe a bad thermostat caused the water pump to overwork? Here is another article:
http://www.import-car.com/bmw-2e81-2...at-water-pump/ "Removed the engine coolant thermostat for inspection and found the engine coolant *thermostat was damaged." |
03-27-2018, 09:06 AM | #9 |
1007
Rep 2,243
I wonder if you can interpret % running as a sign of failure. For example, if it shows a high % then it may be spinning slowly which doesn't provide enough flow and it therefore has to run a higher percentage?
03-28-2018, 11:45 PM | #11 | |
3973
Rep 7,215
On MSV80/MSD80, it works the same way. there is also a c_abc_inc and c_abc_max factor for each error code that can be adjusted to trigger the error sooner/more often. |
03-29-2018, 09:17 AM | #12 | |
242
Rep 1,354
03-29-2018, 01:23 PM | #13 | |
1007
Rep 2,243
03-29-2018, 02:27 PM | #14 |
157
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
Without a flow gauge I think it would be impossible to determine pump health.
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
03-29-2018, 10:03 PM | #15 |
3973
Rep 7,215
