BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      06-06-2008, 01:19 AM   #1
GFP
Drives: 2008 M3 coupe
Calling E92 tire guru's...quick question.
Is running 245 35 19 on 8.5 rims front and 275 30 19 on 9.5 rims for the rears going to be an issue on the E92? Or is a 265 35 19 on 9.5 rims for the rears a better symmetrical setup? I want a wider than OEM setup in the back but Im worried about having a 30 size wall back there looking terrible with 35 walls for the fronts? Kinda clueless about these things...please help...
      06-06-2008, 06:22 AM   #2
icemang17
icemang17's Avatar
41
Drives: 2008 E92 M3 DCT
The difference between a 265 and 275 rear really isn't that much.....but a 275 is about the widest tire you can run on a 9.5" rim without stretching it too much....
Dinan offers a custom wheelset thats 9.5" front and 10.0" rear with 275 front and 295 rear...all that extra tire should improve handling quite a bit!
Brian
2008 E92 M3, MR, DCT, extended BB leather, loaded!
1988 Porsche 928S4, Guards red/Champagne leather
1989 Porsche 928S4 track beast!!!
      06-06-2008, 10:48 AM   #3
Ronin13
Ronin13's Avatar
21
Drives: E92 M3, RRS Supercharged, S2K
One point. A 10mm difference is marginal, but the more you increase the stagger between the front an rear diameters, you are inducing a bit more understeer to the handling balance at the limit.
      06-06-2008, 11:33 AM   #4
ben@tirerack
M3Post Supporting Vendor
87
Drives: 740i
On the M3, the rear tire should be slightly taller than the front, so do not use 275/30R19 with a 245/35R19. Ideally you would go 255/35R19 front with 275/35R19 if you wanted to go wider.
275/35 rear with 245/35 front would *probably* be ok, but the understeer would increase, as noted above. The change in width is what changes the handling balance.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
      06-06-2008, 12:01 PM   #5
footie
footie's Avatar
No_Country
1094
Drives: i4M50
From experience I would not go wider than recommended for the rim. As everyone has said the handling will be affected but what they haven't said is that your tramlining and steering input will also increase, your car will wonder more so over the road and will require more steering input to arrow straight which is a bigger problem as your speed increases.
I remember a customer's car (328ci) with factory fit 17" that was running 225 at the front, in the end the dealer decided to swap these for 205 or 215 at the front and the difference was remarkable.
You should never over tyre a rim.
      06-10-2008, 12:20 AM   #6
malter2.0
61
Drives: em-funf
stretching a tire means you are placing tire thats narrower than recommended on the particular wheel width, not the other way around.
      06-10-2008, 12:41 AM   #7
enigma
13
Drives: E92 M3 and Elise
Correct. On camber limited cars like the e92 this is much less of an issue in the front than pinching a tire.
A 275 will work fine in the rear. By increasing the rear grip the car will put down power better but understeer more. Faster, but perhaps not as much fun.
Manual gearboxes, the rotary dial of cars.
m3post
