Towing confusion
03-15-2018, 09:47 PM | #1 |
1007
Rep 2,243
Drives: 2007 328i / 2014 M235i
Towing confusion
Why does the owners manual recommend towing
A rwd with the rear tires on the road? Shouldn't it Be the front tires which are free wheeling and therefore There is no risk of damage to the drive components due to lack of lubrication? I know flatbed is preferable but not always available I had my car towed 1km with the front tires on the ground And it's perfectly fine, a flat bed wasn't available at the time Very confused ..... |
03-15-2018, 11:13 PM | #2 |
264
Rep 459
The manual specifies flat bed only. Towing an automatic car with the rear wheels on the ground will tear up the transmission because the transmission oil pump isn't spinning. If you absolutely need to tow an automatic with the rear wheels on the ground, you need to remove the driveshaft first.
Towing with the front tires on the ground is discouraged. It shouldn't damage anything (as long as the bumper doesn't drag), but things will get really ugly if the steering turns. |
03-16-2018, 12:41 AM | #3 | |
Apprentice
373
Rep 801
03-16-2018, 02:03 AM | #4 |
264
Rep 459
If wheels are touching the ground while towing, you need to be in neutral, unless the driveshaft is out. In neutral, the transmission is disengaged from the engine, but still connected to the wheels. Without the engine spinning, the transmission oil pump isn't lubricating things. You don't want that transmission spinning without proper lubrication. If you absolutely have no choice, you can tow short distances at low speed, but it's best to avoid this. With a manual, you can tow in neutral no problem.
I think BMW specs something like 45 miles max at 35mph max for towing a rwd automatic. AWD is flat-bed only Last edited by RocketSurgeon; 03-16-2018 at 02:13 AM.. |
03-16-2018, 08:56 AM | #5 |
1007
Rep 2,243
It's 45 mph and 90 miles max when having the rear wheels touch the ground. The engineers must have determined that doesn't cause harm
Makes sense about steering wheel moving, that's why the guy wrapped the seat belt through the steering wheel locking it when he towed my car. If they can lock your wheel it's much easier on the car |
