03-14-2018, 01:43 PM | #1 |
Rep 12
Is a servicing plan worth it?
So my 218i isn't due for a service for 11,000 more miles, currently it's sitting at around 7k miles, I'm just thinking ahead.
I've enquired about the service plan and have been quoted £1,350 as I'll be doing 72k miles in it, here's what's included Would I save a lots amount of money doing it myself? I posted on Reddit and a user said after buying the parts etc, it wouldn't be much cheaper. I'm fairly careful with repairs/maintenance, tend to do my research and take my time but as this model of car is fairly new am struggling with finding DIY videos, instructions and tips. Interested to hear what others think is best? |
03-17-2018, 05:44 AM | #2 |
287
Rep 864
Bonding Moment
Take the opportunity and do the maintenance yourself - treat it as a bonding moment with your 2.
. Plus you can use better oil & better brakes than OEM. As for filters - save even more than BMW OEM and get Mann. . |
03-18-2018, 03:47 PM | #3 |
195
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
Don’t forget to reset the CBS for these repairs/maintenance.
03-19-2018, 12:03 PM | #4 |
289
Rep 556
I have no idea where you live, but if it is near a highly rated independent BMW shop it is my experience that is is far more advantageous to develop a relationship with one of these shops with a carefully thought out regular maintenance schedule, before the car eventually needs any type of repair. Around these parts the independents charge 20% less that the dealerships and they are staffed with mostly former factory trained mechanics. A good relationship with an excellent mechanic is more piece of mind that any standard prepaid maintenance program. And if disaster ever strikes, you have someone working with you to fix your car, as opposed to looking at you as just one more whinny one-time customer.
03-21-2018, 03:29 PM | #5 | |
Rep 12
I have an WiFi OBD device to access the Car's ECU's etc, I'm assuming I can reset this through that?
I'm also heavily thinking about doing the maintenance myself but am struggling to find good sources that show/list what exactly I'd need. The manual simply says to take to the dealership and recommends BMW oil, I also see lots of oil change tutorials on this forum but many are for M cars which I'm unsure would be different from my 218? Also does anybody know if this would affect warranty/problems when I return the car? |
03-22-2018, 02:57 PM | #6 | |
195
Rep 366
Drives: 218i Coupe
1. Without pressing the brake/clutch, press the start/stop button 2. Wait for the service reminder to disappear 3. Press and hold the odometer reset button. You will notice your trip meter reset and then go back to the value it once was. Keep holding for a couple more seconds At this point, service values that can be reset will come up. Use the odometer reset button to scroll through the menu. 4. At the value, you want to reset, press and hold the odometer reset button. "Reset possible" will change to "Reset?" 5. Press and hold odometer reset button again until the value is reset 6. Press the start/stop button to start the car or turn off the car There are lots of videos showing this procedure step by step such as these: |
03-31-2018, 10:36 PM | #7 |
Car Enthusiast
282
Rep 501
OP if you have any question in regards to doing the services your self feel free to send me a PM and i would gladly help you or give you any sort of tips.
If your looking for service information and how to do replace some of it You can use the link i provided below. General maint on these cars is pretty straight forward. Any questions just ask here or PM me is fine. Basically only hand tools you will need to do the repairs are The oil filter wrench/cap to remove the filter, 17mm socket with ratchet for the drain plug. BMW 12 point socket for the spark plugs (can buy these from the dealer or other vendors like Turnermotorsports) Torx20mm and Torx30mm sockets with a ratchet, flash light/trouble light and tire inflator and gauge. https://www.newtis.info/tisv2/a/en/
2016 M235 - Melbourne Red
2005 BMW M3 - Sold Licensed Automotive technician for BMW Regina |
Tpeterson156.50 |
04-01-2018, 11:39 AM | #8 | |
157
Rep 580
Taunto281.50 |
04-06-2018, 12:28 PM | #9 |
15
Rep 50
OP --- Well it all depends.
How competent do you feel doing an oil change? Do you have the necessary tools? IMHO...there are some excellent diy oil change video's on uTube for the f22 n20 228i. Again, IMHO, waiting the recommended oil change interval that BMW expects is just to long. Either 5000 or 7500 miles for peace of mind. Good luck!! biz |
