03-14-2018, 08:55 AM | #1 |
68
Rep 283
Enhanced Bluetooth Coding
Just getting prepared to code my new car (when it arrives) and I wanted to code enhanced bluetooth.
I didn't specify the EBT but know I can code it to unlock the SMS, office integraration. Having done it many years ago on a 1 series I just Change FA from 6NH to 6NS and bingo. Do I need to replace anything on my G30? What VO code do I need to add? Do I need to remove anything from the VO? Is it 6NW or 6NS? thanks |
03-14-2018, 09:51 AM | #2 |
150
Rep 365
Change the following in HU_NBT all to Active
EMAIL_EIN_AUS SMS_EIN_AUS CONTACTS_EIN_AUS CALENDAR_EIN_AUS TEXT_NOTES_EIN_AUS AUDIO_NOTES_EIN_AUS REMINDER_EIN_AUS TASK_EIN_AUS PIM_BILDER_EIN_AUS REMINDER_TRIGGERS_EIN_AUS MACRO_PIM |
VirtualGuitars7855.50 |
03-14-2018, 10:43 AM | #3 |
68
Rep 283
Is it just that simple? No VO changing like before?
03-14-2018, 10:58 AM | #4 |
150
Rep 365
Worked for me using BimmerCode
csm7djs68.00 VirtualGuitars7855.50 |
03-14-2018, 11:04 AM | #5 |
68
Rep 283
04-04-2018, 03:56 AM | #9 |
68
Rep 283
After another attempt at coding ehanched bluetooth on a brand new G30, I can confirm it is possible with bimmercode.
There is a new option called something like MENU_OFFICE_SHOW and this this needs to be set for it to display the extra options. |
04-04-2018, 11:08 AM | #10 |
Rep 23
My g30 is on PCP, if I decide to unlock these features too, will BMW be able to detect that I’ve done it, and will it screw up the warranty or PCP terms??
Gone: 520d SE F10 in Blue
Current: 520d M Sport G30 in Alpine White |
04-14-2018, 05:54 PM | #11 | |
16
Rep 78
OFFICE_MENU_ENABLE |
04-29-2018, 06:17 AM | #13 |
12
Rep 28
BimmerCode gave issues.
Hi all,
I have now an issue that I want to solve myself if possible, with your help. I've had this 2018 BMW 530e iPerformance since Nov 2017 and loving it. I had been using the VGate WiFi adapter and the BimmerCode app to change a few settings here and there. About a month ago I went in again, to change a couple of more settings and right after that, noticed that the car won't charge anymore, gave me a Charging Error message on my BMW app, I have a Juicebox L2 Charger box at home. Tried a few other chargers (110v) and my charging facility (ChargePoint) at work, everything gave the same error. Took it to the dealer, they kept it for a few days, reset all codes and it's back to normal again. I assumed something I did on BimmerCode that may have upset something. A month later, last night, I wanted to code a couple of things which I had done when I first leased the car. I thought it was ok to do that so I went in again, just changed the starting animation to M type, changed the warning sounds to bmw i type, that's all!! And got the same charging error!!! I hate it that I may have to go to the dealer once again. Can anyone please help!!!! Thanks |
04-30-2018, 02:30 AM | #14 | |
68
Rep 283
08-22-2018, 08:28 AM | #16 |
Rep 10
Functionality
I myself have a G31 and interested in also coding with Bimmercode (already registered and used other options with success). My question is what does this bring? - ability to connect a second BT phone? Ability to read textmessages? more?
08-26-2018, 02:44 AM | #18 |
Rep 10
enhanced features..
it also enables ; phonebook pictures.. i expected that in coms section you could choose phone2, but cannot see this still.
08-26-2018, 03:39 AM | #19 |
Rep 9
Hi psu, I did this yesterday on my G31 (Jun build) and seem to have got it all working. In the expert mode list of parameters I found a setting that was something like BLUETOOTH_2ND_HFP which I set to aktiv, this has added the option of a second phone to the display.
08-26-2018, 03:29 PM | #20 |
Rep 10
'itsme' Thanks!, only changed the suggested ones as in beginning of post, will change this one as well , thanks! more options/parameters suggested in relation to enhanced bt?
30/08 add : worked flawlessly, 'itsme' thanks again.. |
08-27-2018, 03:15 AM | #21 |
Rep 9
I’m sure there are more that could be changed, but I have no experience myself and was reluctant to experiment too much just in case I messed something up! If anyone else changed other parameters for enhanced bluetooth, I’d be interested to know.
09-02-2018, 02:06 AM | #22 |
Rep 10
Are there possibilities to turn on 'screen -mirroring' as well? Or do I need to turn on wifi? , and how to do this? (Seems that apple Carplay, which i have connects to wifi, thus hardware wise must be possible)
