BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Eibach pro or Sachs M sport springs on SE??
      03-12-2018, 01:09 PM   #1
Silver Streek
119
Drives: 325d E91
So I bought some Eibach pro springs for my 325d E91 as the SE springs are a bit wallowy and not very planted. Just want that planted feeling I had in my old E46 with sports suspension.
Then I got to thinking g it would be too low and maybe too stiff so I got a set of M sport springs by Sachs from ECP.
I have a set of Bilstein B4 for sports chassis that will be going on regardless.
What do you guys think Eibach or Sachs M sport???
Don't want to scrape speed bumps and want to be able to resell the car one day.... Not for a good few years tho!
Whichever set I don't use I shall sell on.
      03-12-2018, 02:04 PM   #2
dragerboy
83
Drives: BMW E90 330D
Eibach all the way as I believe they are superior. There are lots of us on here who have BMW springs explode whilst driving lol.
      03-13-2018, 08:00 AM   #3
MooLard
28
Drives: 335d touring
I can vouch for that, my E91 has 91k miles on and a front spring cracked last week. I have replaced them with a set of Eibach pro kit set of spring, my car is a sport already so it only lowers the front 20mm and the rear stays the same. It looks good and fine though, hopefully they will last a further 91k miles.
I considered replacing the shocks at the same time due to the mileage but as it was already a surprise cost I have left them for now. Once one leaks at MoT time I will replace all four.
      03-13-2018, 10:50 AM   #4
Maxlude
158
Drives: E90 330D_SE_Man, F90_M5C
I have a 2006 E90 330d SE. The dampers will make the most difference. I found the OE ones had a small window where they worked ok - very load/temperature sensitive - especially with RFTs.
I had Koni FSDs fitted with the oe springs at first (100k - 115k miles) as ride quality was my priority as the suspension was making long journeys tiresome.
Then a rear spring snapped so i upgraded to EPK springs and have run like this from 115k-130k miles. The drop is just right. I get a lot of comments that the car 'sits well'.
The ride is firmer but not in a detrimental crashy way. The handling is improved further with even less roll/squat/dive.
The only negative with this combo, and this has been posted by others before is the bounce from high speed sharp undulations, where the FSDs seem to get caught out. But it's 90% there which is the best thing i have done to this car.
      03-14-2018, 03:44 AM   #5
bishbosh
840
Drives: F30 335d
2014 BMW 335d  [0.00]
Eibach Pro springs are less harsh/crashy than the M-Sport springs. One of the reasons why people with M-Sport models upgrade to Eibach.
My car had SE suspension and I upgraded to Eibach Pro springs a few years ago now, they are nicely matched to a set of Bilstein B8 dampers. and they completely transformed the car!
Not had an issue with speed bumps.
if I've helped - an Appreciate would be, er, very appreciated!
      03-14-2018, 03:46 AM   #6
RajB
RajB's Avatar
448
Drives: E92 335i
Definitely the ProKit. You shouldn't have any issues with speed humps and the like on them as they aren't overly aggressive.
E92 335i / M3 Hybrid - The Build
      03-18-2019, 05:44 AM   #7
E60525d
E60525d's Avatar
281
Drives: 330d M Sport LCI
Whcih setup did you decide on in the end?
      03-18-2019, 06:53 AM   #8
Silver Streek
119
Drives: 325d E91
I fitted the Eibach pro springs in the end. Very happy with them so far. No scraping on speed humps and a marked reduce in body roll, The biggest difference is just how planted the car now feels. Did it myself in 2 afternoons. 1st afternoon I fitted springs and shocks to the front, and the rear springs. 2nd afternoon I fitted the rear shocks.
You thinking of doing the same?
      03-18-2019, 07:53 AM   #9
E60525d
E60525d's Avatar
281
Sounds good. What shocks did you go for? And I presume the ride is firmer now?
      03-18-2019, 08:11 AM   #10
Silver Streek
119
Drives: 325d E91
I went for the Bilstein B4 shocks, there are two vesions of the B4 though, one for the SE and one for the M Sport, make sure you get the M Sport version which is better suited to the Eibach Pro springs..... If you decide on Bilsteins that is.
Ride is firmer yes, but not too firm. I wouldn't wan any harder shocks personally. I think what I did is a good upgrade over the stock SE suspension.
      03-19-2019, 11:22 AM   #11
1 AKY
1 AKY's Avatar
No_Country
459
Drives: F11 530d
Best place to source the Eibach springs and Bilstein dampers?
PM if you wish.
      03-19-2019, 02:18 PM   #12
Silver Streek
119
Drives: 325d E91
I got the Eibach Pro kit from Autodoc https://m.autodoc.co.uk. Think I paid about £110 for the 4 springs, they came from Germany. Probably a good place to get the dampers too.
