03-04-2018, 10:23 AM | #1 |
70
Rep 272
Dots when FDL
So I’ve gone to do some fdl coding.
Read the coding data and clicked edit Gone into the fdl editor and all my folders are dotted and no idea what each one is. Anybody else had this? I’m running esys 3.31.0 with token master pro 3 |
03-04-2018, 01:08 PM | #2 |
451
Rep 1,201
Sound like you haven't set Esys Launcher to F30, F32 ... Not when you connect to the car (F20) itself but on startup of Esys Launcher.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
ryantpayton18.50 |
03-04-2018, 03:25 PM | #3 |
70
Rep 272
03-04-2018, 03:46 PM | #4 |
1388
Rep 2,128
It means your module has been trimmed. The mapping hasn't been updated for that module yet. Later pzdata may cure it.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
03-04-2018, 03:55 PM | #5 |
451
Rep 1,201
Try Almaretto or shawnsheridan there the gurus with this software
03-04-2018, 04:08 PM | #6 |
General
10467
Rep 40,892
Drives: 2018 Alpina B6 650ix GC
Trimmed PSdZData means either E-Sys has Incorrect Target Connection, or you do not use E-Sys Launcher to open E-Sys, or you use E-Sys Launcher PREMIUM but select wrong car Series or this particular ECU CAFD is not mapped in E-Sys Launcher's CAFD Mapping Database.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-04-2018, 06:09 PM | #7 | |
2374
Rep 8,364
If DKOMBI2 or certain HKFM2, it is unmapped in latest launcher and dots are expected. |
06-11-2019, 06:37 AM | #8 |
Rep 25
I'm having the same problem, all dots while using E-Sys Launcher PRO V2.8.2 Build 162 with E-Sys 3.27.1 using PSdZData_Lite v4.17.20 in Windows 10 1903 (not VM), I can view the .ncd files in NCD/CAFD viewer just fine.
Any suggestions? |
06-14-2019, 01:49 PM | #9 |
Rep 25
Figured out finally. Memory setting in PRO Launcher, only Default works, all other settings showing dots..
06-14-2019, 03:41 PM | #10 | |
614
Rep 1,799
I might be talking rubbish but can anyone work out what I am doing wrong please ?
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
06-15-2019, 03:25 PM | #12 |
705
Rep 1,141
06-15-2019, 03:52 PM | #13 |
840
Rep 1,993
Drives: F30 335d
I use tokenbuster too, tokens effectively don't expire.
06-16-2019, 09:05 AM | #14 |
614
Rep 1,799
Do you have to change the date on your PC or is that not necessary anymore ?
06-18-2019, 11:09 PM | #16 |
2374
Rep 8,364
06-19-2019, 01:36 AM | #17 |
840
Rep 1,993
Drives: F30 335d
Yes, but in something like 50 years - which is why I said they effectively don't expire.
if I've helped - an Appreciate would be, er, very appreciated!
06-19-2019, 09:54 PM | #18 |
2374
Rep 8,364
06-20-2019, 06:58 AM | #20 |
840
Rep 1,993
Drives: F30 335d
Mine must be similar if not the same.
11-26-2019, 02:15 AM | #21 |
Rep 4
Hello everyone, first of all thank all the help you give.
Yesterday I correctly encoded 8TH(Speed Limit Info) in the VO of my car along with its certificates (it works !!), to activate it I also had to encode KOMBI, KAFAS2, and HU_NBT, all ok. The point is that after this, I went to check what new fields there are for FDL, but I get folders with dots and not names, as for the version my car is an X4 F26, in E-Sys, I select the F25 version without direct mode, as for the version of E-SYS is 3.27.1, Launcher PRO 2.8.2 build 162, and PSDZ_Data the last one that @shawnsheridan sent me, of the two options that I get to connect E-SyS to my car in As for PSDZ_Data I have tried with both versions F25.xxx.10 and F25xxx.11 (when I codified the ECUs I did it with the latter), how can I see everything again without dots and with the common names? Thanks a lot !! Last edited by mapretel; 11-26-2019 at 04:23 AM.. |
11-26-2019, 05:14 AM | #22 | |
General
10467
Rep 40,892
