F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > check eng light but all systems ok??
GetBMWParts
      02-20-2018, 05:09 PM   #1
bcornwellatl
32
Drives: 2013 F30 328i
All,
Have you ever had the check engine light come on, but when you do a system test it shows all systems ok? I also did a check engine oil (measure) and it shows full - I've disconnected the black terminal from the battery for about 20 seconds and still the light is on... nothing seems to be broken - the car drives fine? but I've got to drive home tomorrow (another 300 miles) and just wondering what it could be?
oh and I've turned off the car a few minutes to see if that may help, but it's still on when I crank it back up....
      02-21-2018, 06:50 AM   #2
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
Get a code reader.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
_bdiddyb_215.00
      02-21-2018, 09:39 AM   #3
switchman
44
Drives: '18 540i '15 X5 '03 530i
2015 BMW X5 35i  [0.00]
2018 MW 540i  [0.00]
Could be thermostat issue; had the same problem recently. I borrowed code reader from Advance auto found P0597 which is failed thermostat.
BMW has extended warranty to cover this problem.
      02-22-2018, 11:40 AM   #4
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
Check your gas cap
      03-14-2018, 12:27 PM   #5
N52 Moistenor
N52 Moistenor's Avatar
20
Drives: 2011 528i RWD
the system check thing on your iDrive and the CEL are two unrelated systems. you need to get your car scanned.
f30post
