02-06-2018, 09:11 PM | #1 |
67
Rep 601
Brake Sensors???
Has anyone replaced their brakes themselves? I wanted to get some input. I saw a youtube video and it only showed one sensor on a front wheel. Some sites for brakes say both sensors or included and Im guessing thats front and rear? I was looking to get the Hawk ceramic ones with slotted rotors or maybe the red stuff ones, anything that will stop all the factory brake dust.
It's not illegal. It's frowned upon, like masturbating on an airplane.
02-06-2018, 09:15 PM | #2 |
989
Rep 2,200
Brake pad sensors are used at the front left & right rear corners.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
02-07-2018, 04:04 PM | #3 |
64
Rep 261
Yes and BMW warns against reusing sensors if you change pads B4 they are worn...something about removing sensor from pad destroys the senor's mounting so it can't lock into place in the new pad.
02-08-2018, 06:36 PM | #5 |
Curmudgeon and Pedant
690
Rep 3,489
This is not correct. The newer sensors (for the E9x and F3x) have a two-stage system. One wire wears through after a short time, to give the system a rate-of-wear; that drives the estimate in the service menu. The 2nd wire, when it wears out means CHANGE PADS NOW!
02-09-2018, 03:02 PM | #6 | |
481
Rep 1,572
Whats the source of that info? According to Turner, for the F-series, the sensor only must be replaced if the Brake Pad warning has been tripped. They do recommend replacing the sensor even if not tripped since they become brittle over time and may fail while removing. I can't find a reference to the two stage system you describe. |
02-09-2018, 04:13 PM | #7 | |
690
Rep 3,489
In any case, I'd replace it - the old ones often crack getting them out of the old pad. Here's one source. The poster is an extremely reliable individual. http://www.e90post.com/forums/showpo...4&postcount=16 and http://www.tomorrowstechnician.com/b...-wear-sensors/ Last edited by floydarogers; 02-09-2018 at 04:33 PM.. Reason: source |
02-09-2018, 05:00 PM | #8 | |
481
Rep 1,572
02-09-2018, 06:26 PM | #9 | |
52
Rep 98
THIS Also, sensors are really fragile and a royal pain to remove without breaking the clip. They're relatively inexpensive. I always just order new ones and yank out the old ones without worrying about re-using them. Plus if you tried to reuse them, and didn't have new ones on hand, and broke the sensor while removing, then you'd have to order new ones, and then get back in there to replace at a later date. Just order new sensors and replace.
2016 BMW F15 xDrive 35i - Imperial Blue Metallic 2014 Porsche 991- Sapphire Blue Metallic |
02-12-2018, 01:25 AM | #10 |
67
Rep 601
are the sensors included in after market brake sets or do those have to purchased from dealer??
02-12-2018, 04:45 AM | #11 | |
No 55mph
1622
Rep 8,476
I buy my rotors from R1Concepts, pads from whomever has the best deal on brand I like, & sensors from ECSTuning And I agree, whether they need replacing or not - best practice is to buy new & replace at every pad change - cost is $56 for both in OEM BMW from ECS - it's not like you change the brakes that often (or at least you shouldn't be on a daily driver) I actually made it a habit to replace the Guide Bushings & Anti-Rattle Clips on the brakes of my BMW's if they have them...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
02-12-2018, 03:53 PM | #12 |
64
Rep 261
If you want to go with OEM pads...BMW has "value parts kit" that the dealers use for Value Service I guess..anyway they include BMW OEM sensor and ECS sells the kits..at least for my E90...was better price than buying pads and sensor separately for sure.
jalx16.50 |
02-13-2018, 12:57 AM | #13 |
67
Rep 601
Im done with BMW OEM pads......the dust is ridiculous. Wanting to go with Hawk ceramic ones.
02-13-2018, 03:08 AM | #14 | |
67
Rep 601
02-13-2018, 03:11 AM | #15 | |
No 55mph
1622
Rep 8,476
Very happy with them - I had a set on my E92 previous to my F32
02-14-2018, 05:00 PM | #16 |
481
Rep 1,572
I installed Hawk ceramics on my 99 540 sport and 08 335i when they came due for their first brake change. Loved them, low dust, no squeal, initial bite is not quite as aggressive as BMW OEM pads (Dust!), but firm and very linear progressive braking. Will be installing them this Spring on my 13 335i
02-14-2018, 05:06 PM | #17 |
1032
Rep 2,382
Just be careful with the sensors and you're fine. Can't hurt to replace them ofc, but I've used the same sensors twice now.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
10-23-2021, 10:05 AM | #18 |
Rep 1
Brake Service light
Replaced front brake pads with OEM parts and brake sensor (NAPA) around 2000 miles ago. Service brake light came on recently and I pulled the tires to ensure everything was still connected (it was). Is replacing the brake sensor again the best option?
10-23-2021, 12:11 PM | #19 |
8245
Rep 16,088
A sensor shouldn't fail after only 2k miles. Check the thickness of that inner pad again. Another possibility is that the sensor came loose at the other end.
