02-05-2018, 09:10 PM | #1 |
43
Rep 155
M steering wheel harness help please
I'm on the tail end of my retrofit paddles on m steering wheel thanks to you guys! Can someone please confirm which paddle connector plugs into which harness connector? The video I watch ( pic attached) said the longer blue connector actually connects to the right side paddle (+). However there is a black plastic holder clip holding the shorter blue connector (- downshift paddle) with another wire that goes to the black controller box. There is no way to plug the black box connector and the shorter blue paddle connector to the left side except maybe take off the black clip. Something tells me that they put that in place for a reason. Can someone tell me which connector goes to which paddle. [IMG][/IMG]
02-06-2018, 07:20 PM | #3 |
43
Rep 155
Then I must have done it right because All connections are made. All steering controls working. The real test will be for paddles when I code it. Just surprised it it was opposite from the video that was recommended on the forum. Link attached. I do have more features than his car and I used original f30 paddles where he used f80 paddles if that matteres. I could probably could have rigged his way to work but it didn't feel right. Fingers crossed.
