F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > EUROPE (Continental) > Fan noise from behind dash?
GetBMWParts
      02-05-2018, 09:29 AM   #1
F30zoom
F30zoom's Avatar
Drives: F34 330d xdrive
Question Fan noise from behind dash?
Guys I have a fan noise that goes with the Rev range sounding behind my dash in the middle any ideas? I can stop it by turning off my a/c which currently isn’t running due to outside temps of 2C so it’s not a/c related
Help pls
Thanks
      02-05-2018, 10:27 AM   #2
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12509
Drives: M4CPC // HP4 Comp.
Does the sound doing a change if increaseing the speed of the fan?
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      02-05-2018, 10:29 AM   #3
F30zoom
F30zoom's Avatar
No mate totally independent from the heater fan. Fan noise goes up and down with the revs
      02-05-2018, 10:42 AM   #4
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12509
No, what I meant: If you have the A/C off and just the fan on and play little with the speed...then anything to hear from the frequency of the noise?
I ask because sometimes the fan soaks some foreign objects against the grilles under the bonnet and sometimes those objects made it through until their get ripped to shreds...but until this finally happens, they're making disturbing noises.
      02-05-2018, 10:44 AM   #5
F30zoom
F30zoom's Avatar
Thanks for that but I have already removed all the rubbish from there. The noise is not linked to the heater fan unit.
      02-06-2018, 01:44 PM   #6
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12509
How old is your car? Maybe the blowby heater itself with a beginning electric motor failure?
      01-02-2020, 05:10 PM   #7
opb20
Drives: F31 330d
Hi @F30Zoom did you manage to get to the bottom this problem? I have exactly the same issue in my 2012 F31 330d. Thanks.
      01-03-2020, 02:02 AM   #8
F30zoom
F30zoom's Avatar
I had the A/C serviced and re-gassed as it was empty this reduced the noise by about 75% but not completely, it was linked to the A/C because if you turned mine off it stopped. Previous owner had been running it empty for sometime.
Hope that helps not a complete fix but good enough.
Rgds
Pete
      01-03-2020, 05:50 AM   #9
opb20
Drives: F31 330d
Thanks, will give that a go.
      01-25-2020, 12:35 AM   #10
Lazlo
Romania
Drives: BMW F31
Help pls
Thanks
Hello,
I have the same noise . It is the cooler from the nav unit . That cooler is almost dead for me and is making noise when is hot in the interior .
      01-10-2023, 07:40 AM   #11
jody391
Drives: bmw f31 330d
whirring noise
Guys has anyone seen this as the culprit to the noise? think the engine is petrol but could still have the same issues on diesels too.
This is from BMW America.
https://static.nhtsa.gov/odi/tsbs/20...47979-9999.pdf
Jody.
f30post
