02-02-2018, 03:17 AM | #1 |
27
Rep 151
Battery Help
Hi,
Got to my car yesterday after work and it was completely dead , cut a long story short got RAC out who got me going and tested battery to show ok (no cells down) . Drove home about 10 miles car fine , started fine this morning just checked voltage and it is at 12.45v and charging fine at 14.5v . I dont have a dash cam or any other items plugged in to be draining it . I am happy to get a new battery and get my local indy to register it but unsure it is the battery at fault , i have bought a power pack as back up in case it happens again , but any info or advice is very much appreciated cheers. |
02-02-2018, 05:13 AM | #2 |
978
Rep 2,069
I would think it was a minor electrical glitch opposed to battery related in that case. Exactly what though, I have no idea. I'd check the battery terminals are tight & just see how it goes & if it happens again, then think about getting it looked at.
/// BM3 + M-Power ///
TopperXP27.00 |
02-02-2018, 09:17 AM | #4 |
6428
Rep 8,502
I have a jump start battery pack in the car. Never thought I'd need it but at a full-day geometry setup the ignition was in for less by periods and I think the air-con fan was left running. Result; insufficient charge in battery to start the engine (330d).
Connected it to the terminals in the engine bay : started first time. DBPOWER 600A 18000mAh Portable Car Jump Starter, Emergency Battery Booster Pack with Dual USB Charging Outputs, LED Flashlight and Compass (Black/Yellow) https://www.amazon.co.uk/dp/B01BF08H..._2biDAb1XM44T5
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
02-02-2018, 10:14 AM | #5 | |
6659
Rep 15,858
If the car doesn't go into sleep mode, potential for a drain as well. |
TopperXP27.00 |
02-02-2018, 12:38 PM | #7 | |
13359
Rep 7,484
Got that too! |
TopperXP27.00 |
