Whats missing in my life?
02-01-2018, 02:04 AM | #1 |
Rep 16
So my airbag light is on and seatbelt warning light. Popped the battery space open and found this. It looks like I am missing some way to connect these. Anyone know how this works? I think I will have to remove the battery and reconnect and then clear the codes with INPA? Something like that.
02-01-2018, 02:28 AM | #2 |
Rep 16
So I realized one of these wires is supposed to be left disconnected, after reading the forum. But what does the other one, with the weird shaped connector go to? I can't seem to find a place to connect either of these. Are they just meant to hang loose?
02-01-2018, 04:47 AM | #3 |
295
Rep 2,202
That is definitely part of the battery Safety terminal. Should be connected to the positive terminal to the side. You do not have to take out the battery to replace this piece. Unfortunately, this may not be a serviceable item. It is designed that in the event of a major crash it will basically cut the power to engine and other components. take a look at this link with pics and you'll see the hole it should plug into. https://www.ecstuning.com/b-genuine-...e/61129217031/
Other cable is left dangling. Transport mode from Factory.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
