01-29-2018, 11:21 AM | #1 |
67
Rep 444
FS: Apex Arc-8 18x9 et42 Anthracite Wheels with PSS & TPMS (Maryland)
*** SOLD *** I’m selling my summer wheel set — square setup of 18x9 et42 Arc-8s in Anthracite with 245/40-18 Michelin PSS. Used for 15K miles on my xdrive 328d so tread wear is as even as it gets. Depending on the car you may require a 5mm front spacer to clear the tire’s rim protector from the strut. Seems to be a manufacturing tolerance as some cars require and others do not — I’ll include the 5mm spacer pair (from Apex) in the sale for free. Note these wheels do clear the m-sport and m-performance from brake calipers without issue (I have the m-perf setup). Wheels are religiously cleaned with sonax full effect and wheels are sealed including the inner barrels. Two of the set are perfect, one has ~5” of curb rash (see img_8547 and img_8548), one has ~1” of curb rash (see img_8542 and mg_8543). There are no bends, cracks, or other structural issues with the wheels. Tires are right around 4/32nds (see pics with dial caliper measurements to the thousandth of an inch). There is no history of tire damage, plugs, patches, or otherwise. Tires are hunter road force balanced by bmw dealer. Includes the 2016 spec TPMS sensors in all four. Check your production date for compatibility, but these work with my 7/2015 production date MY2016 car. Detailed pics: https://drive.google.com/open?id=1Tj...xw9puaO4jvBnY_ *** SOLD *** Last edited by jww///95; 02-12-2018 at 07:11 AM.. |
