12-21-2017, 05:45 PM | #1 |
700
Rep 1,447
Strange long cranking on a 328d
I had a hard time starting the car which was warm at the time. It did crank for 5-7 seconds before starting. It felt strange as it is the first time I ever experienced anything like that. I stop it after while and it restart right up like nothing happen. The only thing I could see is that maybe I wasn't pressing hard enough on the brake pedal. Anybody ever had this problem?
12-22-2017, 09:19 PM | #3 |
8246
Rep 16,091
Pressing on the brake pedal is required so that the car doesn't start and immediately take off. If you weren't pressing hard enough on the pedal the engine wouldn't turn over at all.
12-22-2017, 09:32 PM | #5 |
700
Rep 1,447
Well I guess it all part of bmw legendary reliability. The warranty is ending in March so it's a good time for the starter to fail after that.
12-23-2017, 08:30 AM | #6 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
I had the "long-cranking" symptom in my 2007 E92 335i, and it turned out to be the infamous high-pressure fuel pump problem which was immediately fixed by the dealership at no cost. Aside from that, I've not had any reliability issues with any of the BMWs I've owned. Since yours is a diesel, it could be a fuel pump problem, the starter, or a temperature-related problem. I don't know if the newer diesels have glow-plugs to warm the combustion chambers for cold-starts, but it certainly could be related to the starter not turning the engine over fast enough.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
12-23-2017, 08:45 AM | #7 |
1837
Rep 6,990
Well, there you go...wasn't aware of that, but it sounds plausible. The gas-engine cars have something similar that starts the LPFP so it will prime the HPFP when you unlock or open a door to prevent the same type problem with long-cranking.
12-23-2017, 09:08 AM | #8 | |
6659
Rep 15,858
I'm reading it is cranking... typical speed or slow? Likely fuel pressure, (low or high pressure) if it is not attempting to start while cranking. |
12-23-2017, 09:16 AM | #9 | |
700
Rep 1,447
12-23-2017, 09:17 AM | #10 | ||
700
Rep 1,447
12-23-2017, 09:21 AM | #11 | ||
700
Rep 1,447
12-23-2017, 09:26 AM | #12 |
700
Rep 1,447
Something else that came to my mind could be the transmission engagement I remember looking at the rev around 300rpm while the car was cranking. Also there was much more vibration than usual. Is it possible that somehow the torque converter was partly engaged even with the car in park?
12-23-2017, 09:38 AM | #13 |
6659
Rep 15,858
You need it on diagnostics, to see what codes it is showing, if any.
Both low and high pressure must be OK to get a start. Doesn't necessarily mean pumps are the cause, could be a sensor at fault. |
BimmerMat135699.50 |
