F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > P0597 fault code repair
proTUNING Freaks
      12-20-2017, 09:49 PM   #1
switchman
44
Drives: '18 540i '15 X5 '03 530i
2015 BMW X5 35i  [0.00]
2018 MW 540i  [0.00]
Hi guys !
My 2014 328i with less than 30,000 miles now have thermostat issue as found with with code P0597.
I'm looking for some help/guidance if anyone has done this work.
Appreciate any info. Thank you.
      12-22-2017, 08:57 AM   #2
switchman
44
2018 MW 540i  [0.00]
So no one has done this thermostat replacement themselves ?
My warranty expired 10 days ago so I'm going to work on this myself, maybe someone have the procedure from Bentley.
Realoem and the N20 technical drawings shows confusing location of the thermostat, so maybe the Bentley repair manual could show exact location.
Thanks in advance for any help.
      12-22-2017, 01:38 PM   #3
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
There's an extended warranty on the thermostat on the N20
      12-22-2017, 08:02 PM   #4
switchman
44
2018 MW 540i  [0.00]
I didn't know that, I'm going to check with my SA.
Thank you.
      01-13-2018, 09:27 PM   #5
switchman
44
2018 MW 540i  [0.00]
Thermostat has been replaced by dealer and covered by extended warranty but now the temp gauge slowly goes back down to below quarter mark on gauge even after warming up to normal (about 200 degrees). This happens when stopping and idling for about 1minute.
Has anyone noticed their temp gauge acting this way after thermostat replacement ? I don't remember the temp gauge fluctuating after getting engine warmed up normal temperature.
      01-14-2018, 07:27 AM   #6
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
Weird, sounds like a defective/stuck thermostat. Rare, yet can happen with new parts.
BTW, the N20 2013 X1 had that problem early in 2017, was fixed under warranty.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      05-21-2018, 04:01 PM   #7
Euro-bmw
Drives: All black
I have a P0597 I have. 13 328xi 74km on it have a engine light showing thermostat is open do I need to change only the thermostat or the thermostat and the water pump my car isn't over heating take a lil longer to warm up but it's gets to its normal please help
      07-08-2018, 07:01 AM   #8
Destrovi
Drives: 2013 BMW 320xi
2013 BMW 320xi  [0.00]
What did you end up doing? cuz I just got that P0597 error yesterday. Can I get away with just the thermostat? or should I also do the Water Pump, since I'm there anyways. Warranty ran out about a year ago.
      07-08-2018, 02:56 PM   #9
BashShah
296
Drives: 2012 335i Sedan
if you have anything over 60K Miles then I would do the WP also just for a peace of mind.
I would cause you are right there and 95% of the work is already done.
you don't want to do it again.
Most Likely your CPO will not cover the WP, so my 2 cents, Order a New WP from ebay right now and book an appointment 7 days from now.
worst case, you can return the Ebay ordered WP.
Make sure to buy a OEM brand WP like Continental or Conti brand. (I am not sure what brand is in the F30 Model, call your local Dealer's part dept for that.
when looking up in ebay type this "BMW partnumber" then you will get better results.
Good luck.
f30post
