12-20-2017, 01:23 PM | #1 |
59
Rep 305
Noisy door seals, dealer won’t replace.
I’ve brought attention to them every time my car got serviced. The last 3 times they “libricated” the seals and it stopped the noise for a few days at best.
I dropped off my car for schedule maintainance today and told him about the seals doing the Snap, Crackle, and Pop thing again... The guy tells me “there’s nothing much we can do.” WTF!? So you’re telling me a $10k KIA has better door seals then my $47k BMW? How do I get it escalated if they don’t replace my seals or at the least apply teflon tape? I read that they do have an updated part and I’d rather they replace the seals and Shadow Line trim instead of putting a bandaid on it. |
12-22-2017, 04:51 PM | #2 |
2253
Rep 3,622
If you use rubber cleaner on door seals after each wash you will almost completely eliminate the creaking sound.
Honestly- if they replace the door seals they will be the exact same compound/material and the problem will come right back.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
12-22-2017, 05:50 PM | #3 |
119
Rep 322
I use spray detailer, a microfiber, and run it along the length of the seals with firm pressure and it fully elimates the 'creaking' for about 5,000 miles. Then repeat. 5 minute process.
12-22-2017, 05:57 PM | #4 |
823
Rep 1,910
Do what my uncle did, walked in to the dealer whilst customers were around and gave the service bloke hell at the top of his voice....3 days later ALL seals were replaced, creaking sorted
Happy Motoring
Evdok |
zamboni1130.50 |
12-22-2017, 10:17 PM | #6 |
245
Rep 2,387
I tried Gummi Pflege, silicon, all kinds of stuff. Finally brought it in and they applied Carbaflo. That was in March and it hasn't made a sound since.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
12-23-2017, 08:31 AM | #7 |
8245
Rep 16,086
+1. This is called 'routine maintenance'. Squeaky seals are more than annoying, they're telling you that they're dried out and need to be treated. The penalty for failing to do so is more than noise, it's also premature wear that will eventually result in having to replace them.
tex26702412.50 |
12-23-2017, 01:57 PM | #8 |
44
Rep 117
Drives: 2016 328i m sport
Has the same issue. Took it to dealer and they put Teflon tape on all the seals and the noise is gone now. It's a known problem to them they should know this fix.
12-25-2017, 08:40 PM | #9 |
2466
Rep 5,457
Drives: F30
How... exactly, does one apply teflon tape to a door seal? Im trying to eliminate a creak/click sound and Im wondering if this could be the issue.
12-25-2017, 10:30 PM | #10 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
This is unacceptable when you paid that much for a car and the door seal came with poor quality rubbers. Had the problem with my F30 and my new F80 is experience the same squeaking noise, you have to go the extra miles by applying silicon lubricant for every other months simply it's a poor design on the door seals.
I had the same problem on driver side doors and drive me bonker. Why can't BMW design a better door seals for the 3 series.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
12-26-2017, 07:09 AM | #11 |
6659
Rep 15,858
12-26-2017, 07:21 AM | #12 | |
6659
Rep 15,858
Most of the problem is not the seals at all, but contamination, polishes, etc. I'm very careful not to get polishes on the rubbers, or the critical flock coating on the top edge seal. No issues with any creaking in over 5-years. The fact Teflon tape solves the problem, shows it is 'stiction' issue. The seals don't move freely when contaminated with some polishes. "Too grippy". |
12-26-2017, 07:30 AM | #13 |
2466
Rep 5,457
Drives: F30
Can someone post a pic of where the tape is actually applied? Im clearly confused and may try this to see if it eliminates some creaking that Im hearing.
12-26-2017, 10:20 AM | #14 | |
1131
Rep 5,557
http://f30.bimmerpost.com/forums/sho....php?t=1029827
sspade2466.00 |
12-26-2017, 11:29 AM | #15 | |
18708
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-27-2018, 06:25 AM | #16 |
823
Rep 1,910
Up to now I've had no issues regarding the door seals, maybe its the products I use to clean the car, for those who have take a look at this product its highly rated & the brother says its the bollox for rubber & plastic.
https://www.amazon.co.uk/s//www.amaz...=0&ajr=0&ajr=0
Happy Motoring
Evdok |
