12-16-2017, 01:06 AM | #1 |
83
Rep 123
F30 climate control sucks ass
Hello friends.
Ive owned a 2014 f30 335i for a few months now. I absolutely love the car and the way it drives, but im finding the climate control irks me to no end. Previous to this car i was driving a mercedes w204 c250 alot. In that car, you set the temp to 23'c, press auto and you never have to think about it again. The car blasts aircon till it gets to that temp, and then just keeps it at that temp regardless of how hot or cold it is outside. Even my 1999 nissan silvia will keep the car at a constant temp when set to auto. In the 335i i find that even set to auto, i am constantly adjusting fan speed, temperature and also the little thumb wheel depending on how hot the day is, whether its night or day etc etc. You cant even set the dual zone to the same temp without turning both knobs. Does anyone else find this annoying or am i doing something wrong. |
12-16-2017, 03:41 AM | #2 |
18708
Rep 14,115
Drives: G82 M4C X-Drive
Is it just me or is this post a copy paste from some other thread? Yes, the HVAC is quirky. No, it doesn't behave like most other cars. Owning 2 F30s, a F80 and an i3, I've adapted to it. You gotta burn some calories, but it's not a deal breaker.
Most of the time I set it to 70 all year around and just turn the knob to taste. The climate here in SoCal is pretty tame though.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-16-2017, 04:16 AM | #3 |
823
Rep 1,910
I agree the AUTO setting is a load of bollox compared to most vehicles, my 2003 MERC E320 AUTO setting was the nuts.
Happy Motoring
Evdok |
12-16-2017, 04:48 AM | #4 |
2JZ-GTE
3045
Rep 3,996
12-16-2017, 04:50 AM | #5 |
Big Beaver Smile
2101
Rep 3,791
It's because you don't understand how to use it.
If you're in "auto" you're not "adjusting the fan speed", you're adjusting the "auto program" . There's a difference, you should learn it and maybe you'll be okay with how it works.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
Blubaron791434.50 |
12-16-2017, 07:36 AM | #7 |
981
Rep 1,560
The only one with the type of reply described above is the OP.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
chiefneil771.50 |
12-16-2017, 08:00 AM | #8 |
83
Rep 123
12-16-2017, 08:35 AM | #9 | ||
Big Beaver Smile
2101
Rep 3,791
Seriously, read some of the millions of complaint threads or your OM to learn how to use your AUTO system the way it was designed and find an auto program that works for you. I keep my AUTO program in the middle year round, temp set on 72, dial on blue for summer, red for winter and the only time I touch anything is on an extremely hot day i’ll put it on MAX for a few minutes then back to AUTO once it’s cool. I live in an ever changing climate with some extremes and I’m always comfortable in all 3 of my BMWs. It’s funny you mentioned Mercedes, I hate getting in ours and having the loud fan blasting air at first, I wish it would calm down a bit. I hope i was less dickheadish this time. Sometimes it’s hard for me not to be a dickhead when people complain about something they don’t understand when the information is all over the place.
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch Last edited by wrickem; 12-16-2017 at 08:42 AM.. |
12-16-2017, 08:46 AM | #10 |
Big Beaver Smile
2101
Rep 3,791
Crap!i did it again
SportySpice204.00 Beek707.00 |
12-16-2017, 08:47 AM | #11 |
63
Rep 140
I also hate the blasting fan at start up, but I never use Auto. I just leave Auto off and set it at 72 with the red/blue wheel set in the middle. With this setting I don't have to make any adjustments 95% if the time. I am a hands on type of person so don't mind the occasional adjustment if needed due to extremes.
12-16-2017, 09:36 AM | #12 |
23
Rep 113
I came from an e60 535 that I had 5 yrs to the f30 and that was literally set it and forget it. I set 69 degrees and winter or summer it was dead on. I moved the wheel from hot to cold 3 or 4 times a year. I loved it. This f30 I am always tinkering and can never seem the get the right temp. It's fine in the summer but in the winter it is too hot. My temp is set to 62 and the wheel in the middle and blowing hot like it's set to 80. 61 and the ac comes on blowing cold. I go to far to blue on the wheel and it's a foot furnace and an arctic face blast. I've had the car two years and it's always been that way. Dealer says it's fine, but my blower motor is creaking so I'm going to have them look at the whole system again.
the dope steez404.00 |
12-16-2017, 09:42 AM | #13 | |
772
Rep 1,502
The fan speed when in auto sets what BMW calls "intensity". You can think of it as setting a combination of maximum and minimum fan speed and overall system aggressiveness in reaching and maintaining the set temperature. Higher intensity (ie high fan speed) will try to reach the set temp faster than a lower intensity by blowing more air. It will continue blowing at a higher speed as it approaches the set temp. Once the target temp is maintained it will also blow at a higher minimum speed, although I believe it will moderate the actual temp while maintaining that higher fan speed so as not to overshoot the target temp. Lower intensities are for folks that prefer lower fan speeds and don't mind if the a/c takes longer to reach their target temp. The red/blue thumbwheel on the dash doesn't affect the auto setting or previously described behavior. It only adjusts the temp of the air coming from the dashboard vents; useful if you like different temp air going to your face vs your feet or windshield. Hope that helps. I personally never use auto myself when running around town. I do use it for longer road trips though. |
wrickem2101.00 |
12-16-2017, 10:21 AM | #14 |
508
Rep 2,981
Drives: 2013 BMW F30 EBII
I have owned BMW's since the early 90's and it is somewhat quirky, but I don't even think about it anymore...if I am hot, I turn the knob to blue and the temp down...if I am cold I turn the knob to red and turn the temp up. I have never had a car that I could set to auto and forget about it...I don't buy cars for the ease of the HVAC system...as long as it works, the other aspects of the car should outweigh the HVAC.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
Rhyzen7.50 SportySpice204.00 |
12-16-2017, 10:30 AM | #15 |
420
Rep 842
Geez, what car do I have? My intensity is set to max, both sides are set to 73°. The red/blue thumbwheel is mostly in the blue, as I detest warm air in my face, so sometimes very blue and sometimes in the middle.
I do sometimes put it in MAX on startup, especially if it was parked in the sun. I also use the seat and steering wheel heaters as needed. And that’s it. I adjust the radio more than the HVAC. I did, however, read about the HVAC in the manual, but then again it is my personal policy to “always read the directions”. |
12-16-2017, 11:22 AM | #16 | ||
8245
Rep 16,088
wrickem2101.00 SportySpice204.00 |
12-16-2017, 06:11 PM | #17 |
153
Rep 258
I hate it.
Biggest problem is that if the engine is warm, the heater core gets warmed whether you want it or not and you get a blast of hot air on a hot day. No, other cars, even cars costing many thousands less, don’t do that. And the whole Red/Blue knob makes no sense when you have an Auto mode which is supposed to keep the cabin at a fixed temperature — so why do I need another temp adjustment? Or I can take it off it Auto and Set the temp, but there’s still this weird Red/Blue knob? It doesn’t make much sense. On the plus side, it warms fast and it air conditions well, so at least I’m not left freezing or baking. |
12-16-2017, 07:20 PM | #18 | |
309
Rep 641
You have to accept the quirks. But if you do, it works really well. The visors are garbage though, never have gotten over that |
wrickem2101.00 |
12-16-2017, 08:46 PM | #19 |
Big Beaver Smile
2101
Rep 3,791
I’m right with you there on the visors. THEY suck ass and are dickheads
VictorRomeo145.00 |
12-16-2017, 09:30 PM | #20 | |||
8245
Rep 16,088
It has to, explained below.
12-16-2017, 09:37 PM | #21 |
153
Rep 258
12-17-2017, 05:24 AM | #22 |
238
Rep 878
I have mine set to 21 and it does sometimes get too hot or cold but I use the centre vent to make the cabin a bit cooler or warmer. That is what I assume the bilevel refers to?
