12-14-2017, 10:38 AM | #1 |
725
Rep 1,615
Premium fuel "detailed report" !?
I would like to discuss this with the folks here as I call BS on a company that tests just 6 cars then releases a full 68 page report on Premium Fuel. Am I wrong here?
http://www.thetruthaboutcars.com/201...th-cash-cases/
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
12-14-2017, 11:08 AM | #2 |
109
Rep 295
Drives: 2016 340i X Drive
I see nothing wrong with the article. They tested a few cars with fuel specs that allow regular fuel, but recommend premium. It doesn't apply to newer Bimmers, which require premium. The use of a lower than specified octane can cause knocking and damage the engine.
jeffc83725.00 |
12-14-2017, 11:11 AM | #3 | |
700
Rep 1,447
jeffc83725.00 |
12-14-2017, 11:12 AM | #4 | |
725
Rep 1,615
12-14-2017, 11:32 AM | #5 |
8245
Rep 16,088
I tested mine with two tanks of 89, then two tanks of 91, then two tanks of 89 again. No difference in acceleration or fuel economy, so I stuck with 89. I've done the same with every car I've had going back 30 years, with the same results. Some driving styles might benefit from higher octane, mine doesn't.
12-14-2017, 12:30 PM | #6 | |
725
Rep 1,615
So now the true question is: has anyone tried running 87 and can the vehicle run reliably and well for years to come using it? (forget performance) Required might not be so "required" after all...
12-14-2017, 12:31 PM | #7 |
401
Rep 547
In Chicagoland we usually get 3 choices
87 89 93 So I stick with 93.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
12-14-2017, 12:32 PM | #8 |
245
Rep 2,387
So what are we bickering about here? Saving 30 cents a gallon? Let's say $3 per fill up, $12 per month, $144 per year. Are you kidding me?
We're driving $50k+ cars for god's sake! Just put in what the manufacturer says the engine needs and find some other place to save $144.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
12-14-2017, 12:34 PM | #9 | |
725
Rep 1,615
Not that I want to truly use 87 but it's interesting to see if it's all a big lie in terms of a requirement
Seba77W401.00 |
12-14-2017, 12:39 PM | #10 | |
401
Rep 547
12-14-2017, 12:44 PM | #11 | |
725
Rep 1,615
The debate is if a BMW "truly" "requires" premium or not. (AAA did cover their ass by saying "in most cases" so I am no longer attacking the article itself) I would personally like to know if it's all a load of crap yet the outcome will make no difference as I always load her up with 91 or 93. I know I know, you don't have to say it but inquiring minds do want to know
That seat was meant to be used, are you going to deny it's purpose in life? Last edited by jeffc83; 12-14-2017 at 01:17 PM.. |
12-14-2017, 12:46 PM | #12 |
725
Rep 1,615
Dammit I'd better change the topic title as this is going way off track
12-14-2017, 01:18 PM | #13 |
47
Rep 48
I can't speak to my BMW, because I put 93 octane in it, and don't feel like experimenting.
But my previous car was a modded 2003 Ford Cobra. That's a blown 4.6 liter V8. 8.5:1 compression ratio, and I was running 16.5 lbs of boost. I data logged the difference between the 93 octane my tune was for and 87 octane. The car pulled timing under load pretty much as soon as it hit full boost. Any time the engine was under 50% or so load there was no difference but under load and boost the computer sensed knock and pulled timing early. I was playing with the tune at the time so we were doing dyno runs and data logging. The total difference in HP wasn't that much, but the engine definitely didn't like detonating. I damaged some exhaust valves in the course of one afternoon of tuning. I'd suspect strongly that data logging would show the same on turbo BMW engines. There are engines that are designed to run while detonating, but my N55 doesn't sound or feel like one of them. The particular fire you would be playing with is how fast the knock sensor senses the detonation and how quickly the engine can pull timing to counter it. It doesn't take very much detonation at all to damage things. As a driver you might not even notice the knocks before the engine pulls timing, but your rings and valves will notice them. As to driving, I'd suspect you will never feel the difference from pulling 15-ish* of total timing power and acceleration wise. But you're still putting a lot of stress on the engine for those 2 or 3 revolutions between full boost, and timing getting pulled. Last edited by dogmush; 12-14-2017 at 04:55 PM.. Reason: accidentally said pre-ignition instead of detonation. They are different. |
12-14-2017, 01:40 PM | #14 |
8245
Rep 16,088
If you consistently drive hard, probably. If you don't, probably not. IMO the main reason why not only BMW but most brands recommend premium is that the uninformed might feel that their car isn't all that it should be if it doesn't claim to need premium.
As for 87, I have it on good authority, people in the gasoline industry, that more often than not what comes out of pumps labeled 87 is actually 89. The more grades that a tanker has to haul the less of each it can haul, and that impacts greatly on the cost of getting it to the pumps. There's no requirement that a pump listed with 87 actually deliver 87, it just has to deliver at least 87. If the distributor figures out that it's less expensive to put 89 in the 87 tanks than to deliver both 87 and 89 that's what he'll do. By the same token the 89 tank might get filled with some 91 or higher, especially if the truck has left over 91 that he'd rather dump into the 89 tank than haul it back to the barn. |
jeffc83725.00 |
12-14-2017, 02:09 PM | #16 |
Rep 10
Why would BMW recommend 91 if it's not needed? If anything, the requirement for 91 would hurt sales. I don't by the argument that "It must not be a performance car because the manufacture does not require premium fuel." When the lease was up on my '06 325, I turned the car in and leased a Cadillac. One factor in my decision was the GM did not require premium fuel in the Cadillac. (Premium fuel is about $1./gal more expensive than regular fuel in my neck of the woods. Part if the reason for the higher cost of premium fuel here is non-oxengated.)
12-14-2017, 02:14 PM | #17 | |
725
Rep 1,615
12-14-2017, 02:22 PM | #18 | |
725
Rep 1,615
12-14-2017, 02:39 PM | #19 | |
725
Rep 1,615
We've also confirmed that the car runs just fine on 90
12-14-2017, 02:59 PM | #20 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Pulls timing which knocks down power. The small savings isn't worth it to me on a car I'm buying. On leases, people seem to not care as much as it'll be 'the other guy's problem'. Cheap and selfish but whatever. I run max octane all day/every day. In a car with a potential $20K engine replacement bill, I'll pay a little ins money monthly.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
12-14-2017, 08:53 PM | #22 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Two examples of my timing getting pulled when available octane level did not support the boost during testing.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
