12-14-2017, 01:29 AM | #1 |
286
Rep 506
Windscreen washer not working
Morning
Topped the washer fluid up last night and there is hardly anything come out, but the headlight washer seems to be fine....any ideas? Cheers Virge
Incoming BG X3 M40i
12-14-2017, 01:55 AM | #2 |
773
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
Pump fault, blockage or frozen.
I put my money on blockage or congealed washer bottle. |
12-14-2017, 02:30 AM | #4 |
1399
Rep 8,083
Gunk in washer bottle / filter if you have not been using pukka screenwash. BMWs are very sensitive to supermarket screenwash and / or mixing screenwash.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-14-2017, 02:39 AM | #5 |
849
Rep 1,860
IMO, it doesn't sound like gelling of the screen-wash due to mixing or a broken pump if the headlamp washers are working OK.
12-14-2017, 02:53 AM | #6 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
This all day long... very common.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
12-14-2017, 03:15 AM | #7 | |
1399
Rep 8,083
Ian
12-14-2017, 03:50 AM | #8 |
286
Rep 506
How do you sort this? How accessible is the washer bottle?
Incoming BG X3 M40i
12-14-2017, 03:52 AM | #9 | ||
849
Rep 1,860
edit... maybe there is - looks like up to 3 pumps in total - 1 for windscreen, separate ones for rear Wash wipe and Headlights http://www.realoem.com/bmw/enUS/show...diagId=61_2896 Last edited by moonshine; 12-14-2017 at 04:02 AM.. Reason: RealOEM exploded drawing link added |
12-14-2017, 03:54 AM | #10 | |
849
Rep 1,860
12-14-2017, 04:35 AM | #12 | ||
286
Rep 506
Incoming BG X3 M40i
12-14-2017, 04:59 AM | #13 | |
Rep 56
Washer bottle is nestled behind the front offside wing/arch liner. Not the best of jobs to do in the freezing cold!
BMW G20 M340i - Black Sapphire
12-14-2017, 07:08 AM | #14 | |
1399
Rep 8,083
Ian
12-14-2017, 07:45 AM | #15 |
10995
Rep 32,881
What you could try is run the washer dry then fill it up with very hot water and go for a drive so it sloshes around and dissolves the gunk and spray it all out.
12-14-2017, 11:21 AM | #16 |
286
Rep 506
Think this is worth a go! It's a pity there is the filter at the top of the bottle or else you could try to dislodge the gunk with a power refill....
Incoming BG X3 M40i
12-14-2017, 01:23 PM | #17 |
978
Rep 2,069
This has been covered before. Seperate the washer pipe at the joint in the corner of drivers side bonnet, it's a release-type connection. put a small amount of drain cleaner in the washer bottle, Mr. Muscle for example.
leave it for half an hour. direct the now-seperated pipe into a jug or similar & activate the washers. Empty the lot & repeat until water runs clear... You do NOT want any of the contaminated water on your car.
/// BM3 + M-Power ///
on_the_virge285.50 |
