12-12-2017, 03:36 PM | #1 |
Rep 13
Finding/fixing oil leak
I'm pretty sure I'm in the right forums... I have a 2012 BMW 335i...
Anyways, I'm trying to find the oil leak in my car. it's been leaking for a month or two now but things have been super busy and I haven't had a chance to work on it yet. I've finaly got some time so I put the car up on some ramps, opened the hood and looked around a bit. Please note that I'm lose 1 quart of oil every 2-3 weeks or so. I noticed a few things, some oil is pooling around the oil filter, as well as a couple places behind and under neith the oil filter (see images with oil pooling circled). I've also noticed some oil residue around the genearl area of the spark plugs (again see images). looking under the engine cover, i could see what looked like oil splater on the underside around where the oil filter is. I remove the under body (which was completly saturated with oil) and saw that it had a single spot where oil was still pooled. Looking underneith the car, pretty much everything had oil on it. So... any ideas where this might be coming from? I've already ordered a valve cover gasket, oil cooler gasket, and oil filter gasket to replace since that's what i think the problem is, but thought it would be good to get some feed back from people here. Please let me know if i can clarify anything. Thanks!! *Note: I tried posting the images to the forum, but it didn't work... so here are the link.s https://ibb.co/k3gdAG https://ibb.co/gJ8QqG https://ibb.co/nzBOcw https://ibb.co/eeBOcw https://ibb.co/nQe9Hw https://ibb.co/cYuWVG https://ibb.co/fGULPb https://ibb.co/b6i3cw https://ibb.co/kmrOcw Last edited by gerrg; 12-12-2017 at 03:37 PM.. Reason: Images not posting |
12-12-2017, 03:41 PM | #2 |
629
Rep 965
Drives: 2016 F36 435x MSport
miles on the car?
12-12-2017, 04:22 PM | #4 |
165
Rep 560
Ok so if you see oil around spark plug area your valve cover is leaking. If you see oil around oil filter your oil filter housing gasket is leaking. However unless you're valve cover is cracked I don't see how you would be losing that much oil from just those two gaskets so there is probably one or two more somewhere
12-12-2017, 04:48 PM | #5 |
772
Rep 1,502
I just had the oil pan gasket on my 2014 335i replaced, so that's another possibility.
These N55 engines sure do seem more prone to leaking than the engine in my old E46. |
12-12-2017, 05:12 PM | #6 |
245
Rep 2,387
Oil around the filter is definitely the oil filter housing gasket which is a common problem (is the oil filter cap screwed down sufficiently?) Remember, fluid will travel downward, so if you find a leak on top, you'll also find it down below as it drips.
It's possible this is the cause for oil near the plugs, but that could be a leaky valve cover gasket. First, see if the oil filter cap needs tightening down. There should be a colored marker on the side of the cap that lines up with a marker on the housing body. If there's no mark, there's a torque spec of 20-ish ft/lbs. That's very light, so a good hand tightening with a wrench is OK if you don't have a torque wrench. If it's tight, then you'll likely need to replace the oil filter housing. This isn't hard if you're so inclined. Clean up all the oil on various parts (break parts cleaner is excellent for this) whether you do the repair or have the shop do it and see if you still have a problem.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
12-12-2017, 05:55 PM | #7 |
301
Rep 718
I'd say oil filter housing gasket. Just replaced it on my wife's 128i at 40,000 miles. But a quart every 2-3 weeks seems like quite a bit.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
12-12-2017, 08:10 PM | #9 |
1646
Rep 4,878
I'd say you nicked the o-ring on the filter housing (first picture). That is under pressure when the engine is running. Oil will drain downwards, fan/wind will then blow it backwards.
12-13-2017, 10:59 AM | #10 |
215
Rep 558
You'll be surprised how a tiny leak can have your whole engine drenched in oil. I traced the oil stains all the way up to the highest point in the engine. This led me to the oil filter housing. There are 2 gaskets I had to replaced. When I removed them, they were very brittle. I also had to replace the serpentine belt as oil was all over it. Get if fixed fast because you'll have hours of meticulously cleaning the engine and underbelly of oil -- not fun.
12-13-2017, 02:49 PM | #11 | |
Rep 13
Thanks for all the replies everyone! it sounds like i'm at least on the right track with changing out the valve cover and oil filter gaskets.
As to cleaning the oil off, is there anyway to clean the undercover of the car? it's like a cloth/cardboard type material it feels like, so I wasn't sure if cleaning this would be practical or not, or if i'd just end up ruining it by all the cleaning. Thanks again! I'll keep you all posted on how the gasket replacing goes! |
01-02-2018, 01:52 PM | #12 |
Rep 13
Hey everyone! I replaced the valve Gasket, oil filter housing gasket, and oil coolant gasket and that solved most of the leak. Then i noticed the oil was coming from around the oil filter cap (much more noticeable that it used to). Anyways, I replaced the oil filter and the o-rings and everythings been looking good so far.
I haven't changed an oil filter on a BMW before now (i had a '88 mercury before this so different type of filter all together). Are the o-rings normallly really hard after they've been used? I would have thought they still would have been a little soft, but but the small and large 0-rings were very stiff when i removed the old ones. Figured I'd see if that was normal. Thanks for all the help with this! |
01-02-2018, 02:24 PM | #13 | |
481
Rep 1,572
01-02-2018, 06:26 PM | #14 |
8245
Rep 16,089
01-03-2018, 01:40 PM | #15 |
Rep 13
it's been about 6k miles since my last oil change. I'm just wondering if they didn't actually change the o-rings when they changed the filter. I'll do my own oil change this next time and see how things are holding up. Thanks for the input!
01-03-2018, 01:50 PM | #16 |
481
Rep 1,572
Like Billfitz said: when you do the oil/oil filter change lightly oil the O-ring around the cover housing with clean oil. Just enough the lubricate the O-ring. Prevents the chance of the O-ring tearing or getting nicked and makes screwing the cover down much easier.
01-03-2018, 03:16 PM | #17 |
8245
Rep 16,089
New o-rings come in the box with the filter, so there's no excuse for not putting them in. Some also include a washer for the crank case drain plug, in case you're changing your oil along with the filter.
03-05-2019, 08:31 AM | #20 | |
69
Rep 176
03-05-2019, 08:36 AM | #21 |
69
Rep 176
Any insight on where my leak is coming from?? Im thinking it's from the front oil filter gasket but it looks like it could be coming from the oil filter cap.
Tags |
oil leak, oil leak. gasket |
