12-11-2017, 11:27 AM | #1 |
215
Rep 692
Transmission Software?
Anyone know if there is a software upgrade for the transmission in my wife's 2014 328i M-Sport automatic. I'm not even sure which transmission is in there to be honest. We had a loaner the other day when it was in for an oil change and the transmission in it shifted so much smoother and faster. I know the newer ones have a bit more horsepower, but was not sure if they got a different transmission as well. Love her EB 328i, just would like it to shift better. Let me know your thoughts...
Thanks,
Dave [SIGPIC][/SIGPIC] |
12-11-2017, 12:31 PM | #2 |
481
Rep 1,572
There well may have been a software/firmware update. You will probably have to ask your service department to check your records/read your key to see what version is currently installed and if there is a more recent update that includes the transmission. Then the challenge commonly is to get them to perform an update. Most dealers will only do so if there is service related issue that calls for an update. Some serviced departments are more amenable.
12-11-2017, 07:17 PM | #3 |
2465
Rep 5,457
Drives: F30
Im in this same situation, Im due for my 40k service soon and want dealer to check for any and all software updates but not sure how to approach the issue with my dealer...
12-11-2017, 07:33 PM | #4 |
601
Rep 1,048
If you don't have problems, it isn't clear you should blindly ask for all updates. Sometimes, updates break things that are working. There is a thread about a recent update that screwed up rev-matching on cars with 6MT
12-11-2017, 08:46 PM | #5 |
66
Rep 159
There was an option on your ZF8AT to be purchased, which is called Sport Transmission if I remember correctly. When you buy the car if you didn't pick it you get the base software which shift much slower.
12-11-2017, 08:52 PM | #6 | |
Sedan Driver
389
Rep 1,018
I thought there were some improvements made in the FY14 software
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug Last edited by anotheran; 12-11-2017 at 09:03 PM.. |
12-11-2017, 09:06 PM | #7 |
2465
Rep 5,457
Drives: F30
Interesting. What wife has a 2014 Grand Cherokee and has had more than one software update on engine/transmission already. No charge, obviously...
12-12-2017, 09:09 AM | #8 |
215
Rep 692
Dealer says they will not do an update, even if there is one, unless there is a problem. I say it is shifting slow, so I have a problem. Apparently we are in disagreement.
Thanks,
12-12-2017, 10:08 AM | #9 | |
Sedan Driver
389
Rep 1,018
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
12-12-2017, 11:43 AM | #10 |
114
Rep 243
But you can enable the Sport Transmission option via coding. Which is free if you're willing to do it yourself (I did, it's easy).
Patrick85266.00 |
12-12-2017, 11:49 AM | #11 |
no relation
130
Rep 442
I would probably venture a guess, the loaner had the Sport Auto Transmission (SAT) option, whereas your wife's car doesn't? Perhaps run her VIN number to see if this was an option for her vehicle.
The good news is that you can code in the SAT, I had this done for my car and it does feel like the shifts are bit quicker and less hesitant (as example, see this thread for coding: http://f30.bimmerpost.com/forums/sho....php?t=1138452). I believe the actual ZF8 transmission hardware was updated in 2014 (maybe 2015?), IIRC it added in additional cooling, which allows the "Coast" function. |
12-13-2017, 08:34 AM | #12 | |
114
Rep 243
As for the extra cooling, that is also true, but I don't think the transmission changed at all, just added a tranny cooler. My 2014 has the "Coast" function and I think that may have been the first year for it. |
uncleruckus129.50 |
12-13-2017, 09:39 AM | #13 |
2465
Rep 5,457
Drives: F30
Can you code the sport transmission via BimmerCode? Also, how do you know if you have the coast feature and or tranny cooler?
Mine is a 2014. |
12-13-2017, 12:59 PM | #14 |
65
Rep 240
What exactly is the "coast" function? Is that where the transmission goes into Neutral when you let off on the accelerator in Eco Pro mode?
12-13-2017, 02:53 PM | #15 |
114
Rep 243
Yes, this exactly.
