12-06-2017, 03:08 PM | #1 |
34
Rep 150
F30 OEM - Space Saver Spare Kit
Hi all,
I recently bought the OEM space saver tire kit from a local dealer. My summer tires are 19" and winter tires are 18". This kit is a 17" tire. Just wondering if there is any risk to the drivetrain by running this spare tire if I need to? Thanks. |
12-06-2017, 03:17 PM | #2 |
479
Rep 797
With the xdrive all 4 wheels are supposed to be within 1% of the same diameter of the rest. But I doubt if you go 1.1% different your transfer case will explode. If you calculate that difference of your donut though it is probably significant.
Can you drive at low speeds for a small distance .. maybe, idk. There are reports out there of people even getting a new tire shaved down so it matches the other 3 worn ones. I'm with you though, it really sucks they don't design for a full size spare in the well... [not to turn this into another run flat hate thread, but seriously, stupid] |
12-06-2017, 03:33 PM | #3 |
34
Rep 150
Well, I wouldnt plan to drive more than, say 50-100km at a time, and I am hopefully never going to use this at all.
I am guessing they wouldn't be selling these kits for these cars if there was a significant risk of damaging the transfer case... anyway, looking forward to more opinions on this. |
12-06-2017, 03:59 PM | #4 |
725
Rep 1,615
Sub'd as I need to ditch these run-craps by Winter, which is now lol
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
12-06-2017, 04:06 PM | #6 |
31
Rep 55
Sounds like you're referencing the rim diameter, not the overall wheel size. The sidewall of the tire should be taller to make up for the lesser diameter of the rim. If the overall wheel size is the same as the others you should be fine.
Current...2014 328i xDrive M-Sport
Past.......2008 Saab 9-3 Turbo-X, 2004 Saab 9-5 Aero, 1994 Saab 900 Turbo Commemorative Edition, 2001 Saab 9-5 SE V6 |
12-06-2017, 04:16 PM | #7 |
40
Rep 116
OEM F30 (part# 36112159861) spare tire should give no problems to your cars AWD system. 17' applies to the rim but total wheel diameter is supposed to be within the acceptable size range of any F30 wheel. I believe it is 135/80R17.
12-06-2017, 04:19 PM | #8 |
8245
Rep 16,088
The rim size doesn't matter, the diameter of the tire does. As you go larger with the rim size you go smaller with the aspect ratio, which leaves the tire diameter relatively unchanged.
12-06-2017, 07:27 PM | #9 | |
e90noob
1588
Rep 1,862
as long as the sidewall height makes the overall diameter match the other wheels/tires, then it's fine
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
12-07-2017, 11:20 AM | #10 |
34
Rep 150
Awesome, thanks all.
I bought the kit from the dealer after doing some research. It comes with a bag which tethers to the mounting points in the trunk to make sure it doesn't move around. I'd definitely recommend it for a clean solution. |
12-07-2017, 01:31 PM | #11 |
No 55mph
1622
Rep 8,476
Another important aspect you overlooked is whether the wheel will physically clear the brakes
Back in the E9x days, most came with 17" wheels std and 18" was optional Now it seems that 18" are std with 19 & 20 optional I carried the 5 series donut spare (as many did) on my E92 328iX (never actually HAD to use it) overall diameter of wheel/tire was fine for xdrive AND it cleared the brakes (I did a dry install to ensure it did) But my brakes were the std brakes and not the optional larger performance brakes So make sure to test fit the wheel 1st to make sure it clears all braking components 1st before you find out the hard way some day...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-08-2017, 01:22 AM | #12 | |
146
Rep 36
12-08-2017, 07:28 AM | #13 | |
34
Rep 150
12-08-2017, 07:59 PM | #14 |
Rep 33
Just buy another rim/tire set that matches your current setup and put it in the trunk if you drive long distance. In town, you will most likely just get towed to where you can get your tire replaced or fixed.
In addition, insurance plans usually have roadside assistance. I also have a matching spare in the trunk. Plus, I'm not going to go on long trips without a matching spare in the trunk. I'd rather spend money on a wheel/tire combo that matches my current setup than a spare that doesn't. |
12-08-2017, 09:51 PM | #15 | |
40
Rep 116
Probably close to 40 pounds. BTW, does anyone know how heavy is this European spare tire kit is? |
12-09-2017, 09:22 AM | #16 |
8245
Rep 16,088
A matching spare is more like 50 pounds, and is nearly twice as wide as a compact spare, so on those long trips where you don't want to be without a spare you're losing a lot of luggage space. The compact spare is around 30 pounds. It's also ludicrously expensive, but that's the BMW tax for you.
12-29-2017, 07:11 PM | #17 | |
Rep 33
05-04-2021, 04:20 PM | #18 |
armchair enthusiast
221
Rep 1,019
I can't find this part for the spare tire, mentioned above (3.5 years ago) - "OEM F30 (part# 36112159861)"
I use get bmw parts dot com, have been for a long time. Trying to search for space/saver/spare etc, no luck that way either. Was it discontinued? Is there an equivalent part number now? I want to carry a donut. Thank you.
'18 340i xDrive EB/Dakota, 6-speed manual, M-sport
'02 325Cic vert AW/Montana leather, 5-speed manual, premium/removable hardtop '93 850Ci Oxford Green/Parchment, auto '71 Buick Riviera, 455 V8 land yacht |
05-04-2021, 06:47 PM | #19 | |
Rep 5
https://modernspare.com/product/2013...e-kit-options/ |
