12-03-2017, 04:16 AM | #1 |
35
Rep 172
Difficulties starting and Drivetrain error
When I tried to start the engine, the cranking is about 2x longer than usual, and when the engine is finally started, there would be a drive train error that goes away after restarting. This happened about 3 times in past month. Has anyone faced similar situation before?
I have a n20 with JB4 but currently with the BT kit disconnect, as we suspect the Bt kit was causing CELs previously. Can't really check the codes now... |
12-03-2017, 08:16 AM | #3 |
35
Rep 172
Did the long crank happen every time you start the engine? Mine did 3 times in a month, and other than that, it cranks normally.
I am wondering if it is a battery issue but seems like the idrive will prompt if the battery voltage is too low. Thanks lefthander! |
12-03-2017, 08:26 AM | #4 |
8245
Rep 16,086
Trying to diagnose over the internet is shaky at best. That said, hard starting is usually a problem with either the fuel delivery or the ignition. But even if you knew what the problem was you wouldn't be able to fix it. Take it to your repair shop.
12-03-2017, 06:19 PM | #5 |
35
Rep 172
Thanks billfitz. I have scheduled an appointment with the shop for servicing + fix back bt kit. For Ignition, might want to change the spark plug. Am I correct to say that?
12-04-2017, 02:47 AM | #6 |
2JZ-GTE
3045
Rep 3,996
Pay pay pay pay pay pay.
12-04-2017, 03:13 AM | #7 |
14
Rep 137
It was intermittent, the dealership couldn't fix it and the camgear eventually gave up on me. Unfortunately it was out of warranty and i had it repair out of my own pocket.
12-04-2017, 05:48 AM | #8 | |
35
Rep 172
How much did it cost you to repair out of pocket? Thanks! |
12-04-2017, 06:25 AM | #9 | |
14
Rep 137
Parts alone about 1k before labour. Last edited by lefthander; 12-04-2017 at 06:43 AM.. |
