beyren mesh - choose right offset?
05-23-2008, 03:52 PM | #1 |
95
Rep 1,659
i see that discount tire has reasonable prices on the 18" beyren mesh..
i am installing a set of KW V1's this weekend - but do NOT plan on slamming the car.. maybe 1.5" drop in 18" they have the wheel in 8.5 et 40 8.5 et 30 9.5 et 45 9.5 et 30 i've done the calculations to compare these to my stock 17x8 et34 8.5 et 40 inner clearance - 12mm less outter position - same as stock 8.5 et 30 inner clearance - 2mm less outter position - 10mm out 9.5 et 45 inner clearance - 30mm less outter position - 8mm out 9.5 et 30 inner clearance - 15mm less outter position - 23mm out but what i'm trying to figure out is how this will work in practice.... also - which et will have a larger lip? the lower et? thanks for any advice you guys can offer. |
05-23-2008, 04:11 PM | #2 |
58
Rep 2,201
Drives: 996TT/ae86
In 18's it will be 18x8.5 ET40 and 18x.9.5 ET30 thats what will work and give you the most agressive stance. The KW V1 will pair up nicely.
Generally the lower the ET the bigger the lip can get as well Let us know if yo u need any help with the wheels - http://www.**********s.com/product.a...rn_Mesh_BMW_DC |
05-23-2008, 04:12 PM | #3 |
95
Rep 1,659
does 8.5 et 30 not fit well up front?
also - any idea what these things weigh? i am not going to have to worry about rubbing in rear on 9.5 et 30? going to run stock 255/35 |
05-23-2008, 04:17 PM | #4 | |
58
Rep 2,201
Drives: 996TT/ae86
Don't quote me but I think they weight around 26lbs per wheel . |
