11-24-2017, 09:57 AM | #1 |
Maximus Decimus Meridius
1130
Rep 4,584
Upper plastic coolant line, break easy?
Just wondering if many have had issues with the upper coolant line breaking at the reservoir connection, or the connection on the other end..??
This is the line I'm talking about..
F30 335i Melbourne Red Metallic M-Sport Package |
11-24-2017, 01:26 PM | #2 |
No 55mph
1622
Rep 8,476
I heard tales that it was prone to breaking on my E92 - DIY replaced it under regular maintenance along with every other hose in the car @ 80K miles
Also did the belt tensioner/idler pulley/belt, coil packs, plugs, coolant res tank+cap, PS res+cap, VANOS solenoids Then found a great deal on my new F32 MSport, & promptly traded it in 5K miles later - so the guy that bought it off the lot got a car with all the maintenance pre-done That hose was THE easiest to replace
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
BeastMode335i1130.00 |
11-24-2017, 01:28 PM | #3 |
1130
Rep 4,584
BTW, the reason I ask is because I went and test drove a car at my local Germain Toyota dealer, and it's being sold "as is/whole-sale" with only 49k miles on it, but they refused to fix any of the little stuff, including this coolant hose which is currently broken on the vehicle and coolant was leaking which produced a steamy engine bay after my test drive.. It doesn't make sense that they wouldn't just fix this $30 hose and be able to sell it for a bit more, so I'm leary on pursuing the purchase.. But just thought I'd ask to see if others have had issues with this hose, and if it's a known thing to break.. Thanks..
11-24-2017, 01:30 PM | #4 | |
1130
Rep 4,584
https://www.germaintoyotaofnaples.co...3A9C52EF477763 ^ I went and test drove this, and it drove fine but had a low coolant light on, TPMS sensor light on, and regular SES light on.. I noticed those wheels were removed and most likely the TPMS were swapped off the car to the wheels which were probably kept by the owner, so that doesn't bother me.. The low coolant light and broken coolant hose, does bother me tho, and they weren't willing to fix it and said it's because the car is being sold "as-is" and I just don't get how that makes any sense... My brain is telling me to stay far away from it, but for $22k and just @ 50k miles, it seems like an easy fixxer upper haha..
11-24-2017, 01:43 PM | #5 |
No 55mph
1622
Rep 8,476
Car looks clean from the pics, no HUD though
Someone painted the calipers red also - TPMS prolly not something to worry about (if it is indeed that the sensors are just missing from wheel - which is EZ to tell), but if you get sick of the error you either have to code them out or buy all new sensors for next time you install tires Coolant line is cheap & EZ, but if it were me I would need to know why the low coolant is ON and even more the SES? Will they allow you to run diagnostics on the car with an app such as Carly before buying? Personally, I would never buy ANY car, especially from a dealer, no matter how great the deal is, that didn't have a original or CPO warranty (or warranty of at least some kind) There has to be a reason they don't want to check over the car & attach a warranty - mebbe they already checked over the car & just don't want to fix whatever is wrong Without warranty, and taking my chances, I would offer them 18k at most...
11-24-2017, 03:21 PM | #6 | |
1130
Rep 4,584
And yes I agree that I definitely shouldn't get this thing without a warranty, which is something I questioned to them and they said that they cannot replace these items even if I did add a warranty because the issues would have been there prior to adding the warranty, sounded kind of fishy to me so I'm thinking of backing off this one and not taking any chances as it just seems to have too many issues, many of which seem relatively easy to fix but are being pushed aside because they are perhaps covering a larger issue. I told my friend who went with me that I was going to bring my laptop next time or at least my cable to plug into my phone and run the error memory to see what's going on in there LOL.. I don't know how fond of that idea the dealer would be but perhaps I could sneak it in there without causing too much notice. when I started it up it did sound kind of loud so I thought perhaps I had a performance exhaust but when I crawled under there I seen that it was actually a muffler delete, so the car definitely came from somebody who knew a little bit about the platform, at least I'd imagine anyways.
11-24-2017, 06:57 PM | #7 | |
1130
Rep 4,584
11-25-2017, 06:56 AM | #9 |
1130
Rep 4,584
That was the first thing to came to mind. If I bring my laptop up there and I run INPA on the error memory will that show if it had overheated or went into limp mode?
11-26-2017, 04:03 PM | #12 |
592
Rep 3,870
Yes it breaks easily !
Mine broke out of nowhere, and your car will overheat without it. You have to have it ! This is a very easy fix but it cost somewhere between $50 and $80 in part only. You can change it yourself, but the condition of the car is unknown... It could be very bad to being nothing. From the photos, the coolant HAS leaked and exploded in the engine bay, believe me. |
11-27-2017, 04:28 AM | #13 |
47
Rep 48
I'm not sure I would want to do any business with a dealer that 1. Allows a car to be test driven with a big coolant leak, and 2. Would actually sell a car with that line cracked.
What are you going to do if you buy it, tow it home? Last edited by dogmush; 11-28-2017 at 05:58 PM.. |
11-27-2017, 06:18 AM | #14 |
1130
Rep 4,584
That's exactly what i asked them.. I got the reply, "it's whole sale as is, great deal" lol...
11-27-2017, 06:35 PM | #15 |
215
Rep 558
YES Chinese-made parts! While maintaining the car I noticed the left side of the hose was a little raised and rubbing against metal frame. I pushed it down gently and the piece of shit just snapped off clean. BMW has new part number and is actually better constructed; the bend is now an inch away from the frame. The damn part costs 80 BUCKS!
11-27-2017, 06:39 PM | #16 |
2253
Rep 3,622
Get the VIN and ask a BMW dealership for service history. That will tell you if it faced any real hardships during warranty and of course the car fax
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
11-28-2017, 09:55 AM | #17 |
1130
Rep 4,584
Just spoke to dealer, told them I'm going to pass.. They'll probably send it off to the auction and lose tons of money, which is stupid since they could just fix it but apparently each dealer has their own budget and this one just doesn't want to invest a little to make this one sales worthy.. As it is, I don't even think they should be giving test drives, but w/e.. Thanks for input guys..
